Results 1 to 10 of 10
Thread: Ta 22 Diff Question
    Aug 2008
    N.S.W
    Default Ta 22 Diff Question
    Hi Guys,
    I was speaking to one of the guys at Craft Diffs in Sydney and he mentioned a hilux diff that didn’t need shortening in order to fit a TA22.
    Has any one else heard of this diff, and what model hilux dose it come out of?
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Default Re: Ta 22 Diff Question
    Yeah its an RN2* Hilux. Its about 10mm wider though I think, so not really a problem
    Aug 2008
    N.S.W
    What year model hilux do the G series come out of? and are they the 4x4 or the 2x4 diffs
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    ta22 = 1355mm hub mounting face to hub mounting face.
    rn10, rn20, rn25, rn27 ?? ie early hilux 1970 -1980 ?? = 1370mm
    mind you, these are somewhat of a collectors item and priced to suit.
    Junior Member Grease Monkey Axel's Avatar
    Oct 2008
    OK, so I know this subject has been done to death but I'm going bog eye'd wading through all the info.
    After much fruitless searching for the elusive RNxx Hilux diff to suit a TA22 I've been offered a complete 1985 Hilux 4WD diff for $450.
    Questions: will this be suitable for shortening - changing to 4 stud pattern etc etc for the '22.
    Any help
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    If you are not going to get the narrow diff, and get a latter diff to shorten... then go ahead and do that if you want. If you are going to go to the trouble or shortening everything, then it hardly matters what you start with.
    Both HiLux 4x4 and 2x4 come with the 8" G series diff. In Australia, most 4x4 have the LSD, and the 2x4 have the open centre. There are several ratios also. The diff centres that were is diesel cars have bigger bearings on the pinion.
    If you get the right 2wd diff housing from the 70s ? RN2*, then it probably already has the correct stud pattern also.
    That's probably an RN40 diff then? At 1410mm from memory it will either need to be shortened or use the right offset wheels to make it work. Changing stud pattern isn't too hard, or the mounts, shortening, especially the axels will be expensive I expect.
    Pretty sure no hilux's were 4 x 114.3.
    The 5 stud ones at 5 x 114.3, 1 stud is right, there is a hole directly opposite that already and just needs drilling larger to accept a stud, leaving only 2 for you to work out.
    And most factory ratios suck for street use ie. The easy ones to find are 4.3 and greater
    keep in mind the 4x4 versions are 6 stud too! I don't think most/any of them had lsd till at least the 90's. No standard 80's hilux diff i've ever seen was lsd. Regardless, it's a factory toyota lsd so it'll be stuffed by now anyway.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  1. The old "volvo diff into celica conversion"
    By Toy77 in forum Tech and Conversions
    Last Post: 08-09-2016, 05:30 PM
  2. UCF10 diff question
    By EldarO in forum Tech and Conversions
    Last Post: 07-04-2008, 05:41 PM
  3. quick diff question
    By hypo23 in forum Tech and Conversions
    Last Post: 03-03-2008, 03:31 PM
  4. IS300 diff question
    By blueck in forum Tech and Conversions
    Last Post: 14-10-2006, 11:53 AM
  5. diff differences question :is300/is200/altezza
    By S.W.A.M.I. in forum Tech and Conversions
    Last Post: 24-09-2006, 11:03 PM
