Ok here's my issue. i bought a VPC off ebay a fair while ago. when it came with the obvious problem, no wiring info and no wiring harness. Jackel from this forum was a champion, as he had correct wiring harness lying around and sent it to me. so now i have al the components i need, i just need to double check where a couple wires go from the PVC to the WIRING HARNESS itself. normally the wires are all connected to a 9 pin plug, which is simply connected up. i have to re connect mine myself, i have got every wire sorted except these ones..
number 1 is brown with black dots, no trace
number 2 is red with no dots, no trace. it is connected to a white wire, brown dots, black trace
number 3 is a blue wire with brown dots and a red trace, its tapped into a red wire with black dots, no trace.
so..........
where does number 1 go?? anywhere??
what the hell is number 2 supposed to do, or does it just hang there cut?
is number 3 supposed to be like that? the blue wires were originally seperated, i colour matched them figuring they are supposed to be like that? otherwise they just hang there... it seems logical that they were once connected
not in the picture is a plain green wire and a plain black wire. im assuming the black is ground, not sure of the green one. they both come out of the 9 pin connector from the VPC
most people seem to have the earlier wiring harness, the gen3 1ggte has no info anywhere that i can find on what goes where. can anyone help here??
josh
BROWN wires connects to your FCON if you have one. rest look fine.....now one thing i notice yours has no resistors at all.....the loom i have which plugs into the factory ecu like yours has resistors...
that blue wire if i recall shouldnt be connected like that....
black wire is ground the GREEN wire is to turn on the fuel pump via AFM plug.
1992 - JZA70 STOCK - SOLD
