Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
Thread: stupid 3tgte question(sorry is a real noob question)
    Default Re: stupid 3tgte question(sorry is a real noob question)
    Quote Originally Posted by mullett
    Yeah, tuning is where it's at, I didn't think to ask if it was an aftermarket managment unit. Don't try tuning yourself without a really good fuel/air meter, it's not worth the engine damage...
    RM.
    or just dont try to tune in areas that can lead to easy engine damage.. like high load or boost or rpm....
    then again, tuning isn't that hard if you know what you are doing
    it's not that long ago that there was no such thing as an AFR meter
    my ecu doesnt have data logs. would my autometer air/fuel ratio meter be good enough to use as an example??? it has a constant reading of really rich at idle, and at idle it sounds like its got huge cams.
    I guess so...tuning is a black art to me, something I'm afraid of Me, I'd fiddle till it ran and then drive it gently as all hell to a dyno and throw money at someone until they tuned it for me
    RM.
    well yesterday i sat in my driveway for an hour and put in my new map, 30% less fuel then a 18rgeu. but because it sat so long idleing my plugs wont let it hit boost any more
    il just rego it and take it to the dyno,
    laterdays
    ok i just got my 2tg dip stick out and it is miles too short. the dip stick that is in the engine has a number on it though, it says 15301- 88280 does that mean anything??
    laterdays
    oh i think i worked out wats going wrong with my engine too, only 6 of the spark plugs are going fully black, the 1st cyl plugs arent getting fully killed just a slightly rich burn. i think one of my injectors isnt working properly
    Junior Member Domestic Engineer TA22 GT's Avatar
    Yep, the number 15301-88280 is the Toyota part number for the 3T GTE dip stick.
    cheers,
    Simon
    ok so i have too much oil in my engine, would this make my oil pressure a lil bit higher?? my oil level is 1-1.5 mayb close to 2 litres over the full mark. but that means that the engine only needs about 3 litres, does this sound right?
    thank you
  8. #38
    No it doesn't sound right. The total oil capacity for a 3T GTE is around 4.5 litres.
    Your dipstick has the right number, BUT something is wrong if its only taking 3 litres.....
    Has something been done to the sump? OR check that the dip sitck holder tube hasn't been swapped or cut shorter for some reason.....This might be your problem.
    This holder tube just presses into the block. Measure the distance from the top of the holder tube to the block and we cna check its the right length....
    Simon
  9. #39
    Dude,
    Whats the engine number on your block? I assume its a 3T and not 2T bottom end?
    Simon
  10. #40
    Classic Not Plastic Domestic Engineer ace's Avatar
    hmmm this is interesting....
    good work trying to help him though simon.
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
  11. #41
    it is indeed a 3t bottom end (how many digits should the engine number be?? im not sure if i can see it all or not). i have the dip stick tube sitting beside me, it is exactly 15cm + 15mm inside the block. the sump looks normal to me.
  12. #42
    Hmmm, 150mm sounds right. I give up dude. Without seeing it I don't know what the problem is.....
    Simon
  13. #43
    ok, thanks for al thew help neways
    laterdays
  1. 3TGTE question
    By ta23 in forum Tech and Conversions
    Last Post: 22-02-2006, 11:40 PM
  2. Another noob 18RG question
    By tricky in forum Tech and Conversions
    Last Post: 22-02-2006, 01:37 AM
