Results 1 to 2 of 2
Thread: 1JZ MX83 tacho issues
    Default 1JZ MX83 tacho issues
    I have a 1J in my MX83 and recently my tacho developed a strange symptom. Every now and then the rpm needle would dip to zero and then back or even just sit very low, like 100rpm or something, while the car is on and idling. It seems fine when I drive around.
    I also keep getting an intermittent engine light, code 13. It doesn't always come on, only on idle ocasionally. the car still runs and responds perfectly.
    What I would like to know is, is code 13 and the tacho responding strangely related? What actually sends the rpm signal? Is there a sensor somewhere that needs to be replaced on the engine or gbox somewhere?
    I have already changed my ecu caps, did nothing, also I'm not using a tacho booster, I'm using a jzx81 analogue cluster.
    Any help appriciated with the starnge tacho readings and especially a code 13 fix.
    Default Re: 1JZ MX83 tacho issues
    Anyone got anything??
  1. 1JZ into MX83 misfire at 3k rpm
    By Yammies in forum Tech and Conversions
    Last Post: 27-01-2008, 02:55 PM
  2. 1JZ into MX83 Cressida Conversion
    By matt100kw in forum Tech and Conversions
    Last Post: 18-03-2007, 09:06 AM
  3. Clutch Lines for 1JZ in MX83??
    By gurumaster22 in forum Tech and Conversions
    Last Post: 03-02-2007, 09:04 AM
