Results 16 to 18 of 18
Thread: rear auto transmission seal removal help
    Default Re: rear auto transmission seal removal help
    Output shaft should have almost 0 movement.
    Nov 2007
    that looks like usual wear when the extention housing bush wears out. Now hopefully only the bush has worn and not the extention housing, but with that amount of wear I would not be sure.
    Was it not giving you a vibration?
    go to any auto trans place, they would more than likely have a second hand extention housing, new bush and seal.
    If you was in south aus I would have got you to come to our workshop.
    Mar 2008
    Bit of a thread revival here, but I have a quick question. I've been trying to remove the seal for the last hour now. I have the dust cover off but I cannot remove the metal that's shown by the green dotted line in the first post. Is that part of the seal? The replacement seal is all plastic/rubber. I have damaged the metal already trying to remove it as it simply won't budge!!
    Any help would be amazing!
    Al
    '77 YAMAHA XT500 - Project
    The Drivers' Vault
    By The Witzl in forum FAQ
  2. DIY: My Celica-Supra (MA46/47) differential swap into AE86 & info.
    By assassin10000 in forum Tech and Conversions
    Last Post: 15-12-2008, 02:12 PM
  3. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  4. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
