Results 1 to 7 of 7
Thread: Disabling the steering lock
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    Default Disabling the steering lock
    G'day,
    I need to disable the steering lock in my AE71 for motorkhanas, id prefer to keep the ignition just need to disable the locking pin, does anyone know where the locking pin is so i can snap it off/grind it off?
    Regards,
    Phill
    Default Re: Disabling the steering lock
    On the TA22 its in the metal housing that the ignition switch mounts to. You have to drill out the bolts from memory to remove it.
    Got it,
    Removed the whole housing it was inside that, there was a press in disk, drilled a hole in that and levered it out, then pulled the spring out, got the key shaft out and the lock slid right out.
    Thanks
    is the car stolen? cant see why you would need to modify it.
    The regs for some events require it be removed/disabled
    My KE25 thread
    i lernded sumfing neew!
    i did not know that, what events out of curiosity?
    Most events above 2S. Unless the car is road registered.
  1. steering option - 1982 XT130 corona
    By slo78u in forum Tech and Conversions
    Last Post: 30-05-2008, 04:24 AM
  2. Installing Solex Door Locks
    By RA35GT in forum Tech and Conversions
    Last Post: 21-05-2007, 08:26 PM
  3. How to install lock spacers
    Last Post: 31-01-2007, 04:15 PM
  4. Removing the Steering lock.
    By NeoNasty in forum Tech and Conversions
    Last Post: 14-12-2006, 05:49 PM
