Results 1 to 9 of 9
Thread: blocked 4agze /4age waterway, how to unblock
    Junior Member Grease Monkey cartledge_uk's Avatar
    Nov 2007
    Newbury, UK
    Default blocked 4agze /4age waterway, how to unblock
    I'm rebuilding a 4agze and have a problem
    On checking the waterways, spraying (WD40 etc) into it shows its blocked, I cleaned out the downward with a drill, but its still blocked.
    somewhere on the dotted line.
    Any ideas?
    Default Re: blocked 4agze /4age waterway, how to unblock
    is that the oil hole?
    edit: seems not http://www.philskies.net/library/peter/4age-block.jpg
    does the metal between the cylinders join there?
    perth
    your just going to have to work at it with differant peice's of wire, is that the only blocked path ?, it mite be a good idea to get the block acid bathed and de-scaled.
    is the bottem end together ?
    Get the block chemically cleaned.
    www.billzilla.org
    Toymods founding member #3
    Nov 2007
    Newbury, UK
    The block was stripped down (completely) and checked for flatness etc, and tanked.
    Only on build up did I notice this was blocked. Its sludge, i'm 99% sure the H/g went on this engine its oily like deposits.
    I solved it, mixture of wire, nitromors syringed in and carb cleaner. It unblocked it.
    Wahoo, pistons going in this weekend
    Cheers for the help
    Apr 2007
    Glad you unblocked it ..
    But i am curious does the head gasket actually have a hole in it that actually lines up with the said hole ? ..
    Tallahassee, FL USofA
    Quote Originally Posted by cartledge_uk
    'nitromors', paint stripper/remover?
    Thanks. I'm surprised it was wasn't siamesed.
    i had that problem when rebuilding the vermin, was a small coolant passage, couldnt un-block it and runs sweet with-out it.
    Nov 2007
    Newbury, UK
    Quote Originally Posted by feral4mr2
    Piece of mind there then, is a major pain in the ass to sort out (one of the reasons I stopped the rebuild for a while), but did it.
    lexsmaz - yep it does
  1. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
