Results 16 to 21 of 21
Thread: IDing flywheel
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Default Re: IDing flywheel
    6 bolt with an offset hole.
    Not 8 bolt.
    We had many laughs when the new guy freaked out when he bolted the flywheel up to a manual conversion we were doing. ARRRGHHH the flywheel is wrong!!!
    We pulled the bolts out and spun it around a bit. He was much relieved
    back to topic
    SR20 has a 8 bolt crank
    the sr20 in the shed measures about 69mm (ruler) center to center. The spigot I.D. is around 20mm (ruler again).
    Vernier batteries flat
    Its setup for C4 but centers should be the same.
    Edit: so maybe CA18, SR20?
    If you work out its for sr, i got dibs
    cheers mate that is quite likely then. Hmm crank mount (hub, whatever) is only 20mm? Could do you a rough ring gear diameter estimation?
    108 teeth, 35mm flyhweel mount hub(ruler), 90cm cirumference (tape measure bent around flywheel), 28cm diameter.
    Like i said its for a C4, but looks like factory flexplate.
    Not looking good for SR...41mm flywheel mount hub and 305mm ring gear dia (outer edge)
    Sounds a bit big for a 4. Im banking on a 6cyl. Maybe VQ?
  1. 2jz flywheel bolt details and flywheel thickness - help ?
    Last Post: 28-12-2011, 02:53 PM
  2. Standard 7M flywheel with 6 puck sprung clutch
    Last Post: 10-04-2008, 01:11 PM
  3. 20V Conversion, need to find a flywheel HELP!
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 14-07-2006, 03:34 PM
