Page 8 of 35 FirstFirst ... 67891018 ... LastLast
Results 106 to 120 of 511
Thread: Wakefield Park Track Day - Friday 7th of November!
  1. #106
    Default Re: Wakefield Park Track Day - Friday 7th of November!
    You win.
    I have a loose crank pulley, that may have been loose for, ...a long while. Probably should investigate what damage has been done...
    Apart from that, not much.
    Edit: Well, there's the ecu install, but we all know that's not going to happen by then, so not much point putting it on the list. Oh and i need to silicon my hektik tailights so they don't fill up with water when it rains. If i think about this much further more stuff will probably surface...
    Toymods Club Member
  2. #107
    Mine varies depending on what car i want to/am able to bring
    ST162 list is basically:
    Get the farken thing going....
    ST185 list is:
    New wheels and tyres
    New radiator to help aid cooling
    Maybe an undertray to help aid cooling
    Maybe a proper oil cooler to help aid cooling
    Maybe a water spray to help aid cooling
    Increase the boost to ~12-13psi (omg how will i manage that one) to undo any aid to cooling that may have been achieved
    27.90s @ Esses Hillclimb
  3. #108
    Mine was only covered at the top level too, if I go into detail the list grows much much longer i.e. to refit the diff requires solid round-bar to be turned down into new locating dowels x 4.
    The axles need 0.5mm turned down on the spigot OD to locate the new discs.
    New tailshaft bolts need to have the length turned down ot the correct length on the lathe.
    The HB needs a steel plate mount to be fabricated.
    etc etc.
    But I try not to focus on the minor details and just think big picture
    My KE25 thread
  4. #109
    Which means there's time to ponder which bolt you forgot to insert as you spear off the end of the straight on a sandy ride to the armco
    Corollas only have 8 bolts in the whole car in total so forgetting one is not likely
    My KE25 thread
  6. #111
    that would be true...if we weren't talking about Rolla drivers
    Corollas are slightly less complicated than a horse drawn cart so that means I don't struggle too much with the technology.
    My KE25 thread
  8. #113
    Thats correct!
    I had lost two of my 8 at WSID massive weight reduction made it run its old PB. :0
    I have a long list too but you guys will freak when you see it at toyofest / wakefield. (I hope)
  9. #114
    I'm going to hide my freak out and act unimpressed just to crush your hopes
    Just finished the tedious task of cleaning cleaning cleaning and finally painting my new rear calipers so now they'll be ready for assembly with a new kit through them.
    I also "massaged" the diff region of the floor pan to relieve a few diff to floor pan contact points. Then re coated with underbody deadener.
    My KE25 thread
  10. #115
    200kw atw swapper Backyard Mechanic TIMTAMS's Avatar
    well...i have to sort out the tapping/knocking noise coming from the engine, Fit the "roadrunner" prepped struts and brakes (coilovers, koni adj, 4 spots etc).
    Fix electrical earthing problems
    Remove one of the many bump stops out of the rear
    Oh no the list just grows!
    KE55 3TGTE 234rwkw 11.7 @ 119mph
    Suzuki B-King 10.2 @ 135mph
    FPV GT daily SC 5L 390rwkw 11.9 @ 121mph
  11. #116
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    ill try to be there with my 185...are non toyota owners welcome to come along? ive got a few mates with e30 bmws that would LOVE to participate
    JZZ30 Soarer
    wow....only one toyota now, at one point i owned 6....whats happened to me :S
  12. #117
    Hell yes! Cars of all sorts turn up
    there are a couple of beamer regulars, was a ferrari last time, etc etc
  13. #118
    The more non toyota's i get to toast the better
    Mmmm Bickies Domestic Engineer GriZZly's Avatar
    yay another gt4 ill get to eat up with the beamer .. Bring on the e30s.. ive got a few mates lined up with e30s as well (if they man up and up ) so should be good fun..
  15. #120
    too early to make jokes about more beamers going into the tyres at the end of the straight?
  1. Wakefield Park Track Day - Friday 20th of June!
    Last Post: 14-08-2008, 10:59 AM
  2. WAKEFIELD PARK TRACK DAY – MAY 17th, 2008
    By BigDaddy in forum Previous NSW Events
    Last Post: 28-04-2008, 08:25 AM
  3. Wakefield Track Day Friday 17th Feb
    Last Post: 06-03-2006, 08:38 PM
  4. Wakefield Track Day 4th of November
    Last Post: 17-10-2005, 01:38 PM
