Results 31 to 45 of 48
Thread: car seems slower after manual conversion
    Default Re: car seems slower after manual conversion
    Quote Originally Posted by Kyosho
    MOS: The ECU is throwing codes and flashing the CEL.
    What I have told him to do, WILL fix the CEL issue.
    How much of a wager are you willing to put on that?
    If he wants this to stop, the easy fix is to throw the resistors in place.
    WHY? Because the ECU detects that it's throwing a voltage out, but getting nothing back. Hence, throw the correct resistor in there (Instead of the solenoid) and the ECU will be happy thinking there's a "gearbox" and at least fix the issue of the CEL.
    No.
    For starters the CEL is not related to the gearbox - it's the O/D OFF light that gets activated by a "malfunction" in the transmission.
    Don't forget the speed sensor signals which are also needed for the transmission ECU not to barf. Maybe in the commo the resistors are enough, but with a toyota ECU the speed sensor would also be needed.
    (If you don't hook up SP2, transmission ECU might assume you're stationary, but then SP1 to the engine ECU would either tell the transmission ECU it's moving if present, or throw the CEL on if not present - in any case without two speed sensors, one of the lights will be on).
    The user is complaining one, of a "slow" feeling car after a conversion, and also of the CEL being on, and O/D light flickering.
    CEL is not related to the gearbox, and the O/D OFF light, being picky, should be removed because there is no auto transmission present.
    I was also under the impression that the original poster was more concerned about the "slow" feeling than the lights.
    Mos.
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Quote Originally Posted by Mos
    No.
    Mos.
    OK fellas, we dont know exactly what the problem is here, so its to difficult to say "this will do that" and it is getting on the technical side of things a little i have to admit now so....
    Im sure all of the information has been taken on board that has been discussed here. Who could know what to do for sure without test driving yourself and seeing the behaviour of everything anyway! Just Ideas and maybe some advise can be taken in from all thats been discussed as too the next step that is to be made.
    Nov 2007
    Maybe like MOS said you just haven't got used to the gearbox yet, since its a very heavy car with a underpowered engine, you should rev higher in each gear before changing.
    Junior Member Backyard Mechanic VasH's Avatar
    "error code 52 Engine at > 2000 rpm and no signal received from knock sensor"
    Is this bad? how do i fix it ? thanks
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    Wire under the intake that you spoke of earlier - sounds like it might have been the knock sensor?
    lol turns out that was it must of knocked it off when i was putting the starter back in, sigh.
    thanks a heap everyone for the advice anyway
    Its drives friggin sweet now!
    Quote Originally Posted by VasH
    Hahaha. good stuff mate
    The car will run like crap with the knock sensor unplugged!
  8. #38
    Quote Originally Posted by Aust162
    yea it was running like my gf's mazda 121 and after cleaning up the engine bay today it was amazing i made it home....
  9. #39
    Does this thing have traction control?
    If so it may be confused by the gearbox change.
  10. #40
    Riverina Chapter Automotive Encyclopaedia andyroo's Avatar
    Sounds like a pod racer
    2009 Toyota Hilux SR V6 4x4
    2000 Toyota Avalon Grande -SOLD 2014
    1985 Toyota Celica XX 1G-GTE - SOLD 2014
  11. #41
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    that sounds really rooted!
    1992 - JZA70 STOCK - SOLD
  12. #42
    yea i fear the worse too, oh well aslong as it holds up until i can chase another one ill be happy
  13. #43
    1) for future reference ALWAYS check what codes are being flashed at you before assuming they are innocent and ignorable. This problem would have been fixed 2 pages ago.
    2) there is an issue in your layshaft bearings, my advice is to swap out the box for a known good one (cheap option) or replace all bearings and be happy the box is not likely to have bearing problems for a while longer (lots more expensive, better result, and I advise to pay somebody to do this unless you are uber confident and have played with similar things before)
    3) piss the OD light off unless you intend to go back to auto later
    4) keep the twinplate clutch, they are the best thing since sliced bread for a street driven high performance car with a manual.
  14. #44
    May 2008
    Get the box rebuilt like omanra23 say make sure its a proper rebuild. No point buying another box that may die in 2days or 2 years. to get rid of the OD light either take apart the dash and put black tape over it or get a manuel ECU that removes the OD light for good...or just live with it I did for 4 years lol till i scored a EBAY gen 3 ecu foir $10 CHEAP!
  15. #45
    Quote Originally Posted by GA70H_92
    Yea im looking into it, most places are around 800ish if i take the box out and drop it in. Though im looking at a really low k' box from another importer but its just as much as reconditioning
    yea im not fussed about the light its not an issue anymore, ill cover it up at some point
    Im seriously considering just getting another car, im not really in a position to stuff around so much with my daily as i used to be, when i had a big car port and work was a 20min walk, if somethin stuffed up it was no drama.
  1. RA23 Auto to Manual Conversion
    By Night Rider-TA23 in forum Tech and Conversions
    Last Post: 18-10-2007, 07:23 AM
  2. Nissan S15 Auto to Manual Conversion
    By mr2lover in forum Tech and Conversions
    Last Post: 19-03-2007, 07:18 AM
  3. mz20 manual conversion
    By payney8 in forum Tech and Conversions
    Last Post: 21-08-2006, 11:51 AM
