Results 1 to 4 of 4
Thread: Bypassing neutral starter switch gz20, a340e
    Junior Member Backyard Mechanic VasH's Avatar
    Default Bypassing neutral starter switch gz20, a340e
    Hey im almost done with my manual conversion and was just wondering whats the best way to bypass the neutral starter switch im looking at just removing it from the box and securing in the park position somewhere, or if anyone knows what plug and wires to cut and join that would be greatly appreciated!!
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    May 2008
    Default Re: Bypassing neutral starter switch gz20, a340e
    there will be a plug with 3 wires.....Blue, black and white, if i recall you join the blue and white together also while your there you will need to hook up the reverse light switch to one of the plugs...i can check tommorow if you like during daylight................
    1992 - JZA70 STOCK - SOLD
    Thanks mate i will try it out!
    oh yea if you can that would be sweet!
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    yup pretty sure you bridge the blue and white for neutral start bypass. the reverse lights are the black wire.
  1. GZ20 overdrive switch help!
    By indeecent in forum Tech and Conversions
    Last Post: 08-05-2008, 07:17 PM
  2. Need help with bridging the neutral start switch
    By frk5how in forum Tech and Conversions
    Last Post: 28-11-2006, 12:45 PM
  3. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 09:34 PM
