Results 1 to 9 of 9
Thread: Cross threaded Front control arm bracket
    Junior Member Grease Monkey KOV51's Avatar
    Default Cross threaded Front control arm bracket
    Hi peoples I was installing my front drivers side control arm on AE82 Twin cam hatch and there is a big U shackle holding the caster bush to the underside of the chassis. I had previously installed this shackle back in place and did it up to factory torque spec when I was installing brake calipers later on I realised I had used the brake caliper bolts on this by accident and I removed them and swapped the bolts however upon reinstallation I cross threaded the start of the thread into the chassis after much playing around I havent been able to get the original thread to take up. What is my best course of action now? the bolt isnt damaged its a 10mm thread fine pitch bolt.
    Any help would be great.
    AE82 Turbo "BONKRS"
    Default Re: Cross threaded Front control arm bracket
    helicoil kit
    makes a stronger thread too.....
    I have never used them how do they work etc?
    AE82 Turbo "BONKRS"
    Quote Originally Posted by KOV51
    -You drill the thread with the approate sized drill bit
    -Tap the hole with the tap that comes with the helicoil kit
    -Screw the helicoil in with the tool provided
    -And break the end of the helicoil (the bit that you turn)
    should come in a kit similar to this
    get them from blackwoods, or coventry fasteners.
    its a drill and tap set that enlargens the whole to a special size thread, and then you use a special tool to screw in a coil of metal that turns the whole into whatever size/pitch you want.
    http://www.engineproblem.com.au/helicoil.htm
    awww man now my chrome bolt wont fit lol
    AE82 Turbo "BONKRS"
    Nov 2007
    Or, is it possible to drill it out and put a nut on a longer bolt that goes all the way through?
    someone mentioned I should buy a tap and just thread it
    AE82 Turbo "BONKRS"
    How badly is it threaded?
    One or two threads up the top?
    Using a tap should work because of its taper at the start of the tap.
    Try everything before you go drilling it out.
  1. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
  2. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  3. MA61 KYB Front Shocks Question "The Shocks Thread"
    Last Post: 01-02-2006, 09:58 PM
  4. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
