Results 16 to 18 of 18
Thread: LPG Carb options.
    Default Re: LPG Carb options.
    Dave.
    When I ran my car on the dyno earlier this year it ran lean on LPG above about 4500rpm.
    I tested it today by watching the output from my narrow band O2 sensor and it still runs lean above about 4500rpm. I then clamped the balance pipe and vented the converter end to increase the LPG vapour supply pressure. It started to run rich instantly but still ran OK. Bit of a rough idle. So giving it a blast it still ran lean at about 4500rpm. I am thinking this when I hit the flow capacity limit of the JB converter.
    Any thoughts.
    With my narrow band
    vic
    , Balance lines dont do much on non boosted applications. Clamping the line locks the convertor in 1 position tho and if you drop the load it will richen up.
    We allways used to fit them but not so much on the impco stuff now.
    Can someone please +rep cambelt1 for his help.
    Helpful informed advice without serious attitude.
    I can't do it because I have done it before. Must be on another thread.
  1. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  2. twin piston caliper options.
    By MR22ZZ in forum Tech and Conversions
    Last Post: 13-09-2006, 03:52 PM
  3. intercooling 1ggte on gas carb
    By love ke70 in forum Tech and Conversions
    Last Post: 28-03-2006, 07:31 AM
