Results 1 to 4 of 4
Thread: 7M error code help
    SignWriter Grease Monkey MZ20's Avatar
    Default 7M error code help
    Hey guys, got the 7m fired up tonight and it's throwing error code 51 which i believe is a no TPS signal?
    The only thing we have done with the TPS is had it unplugged, it never threw this code before the HG repair...
    Does anyone know of anything i can check?
    The other thing is when we adjust the CPS the revs rise quite rapidly from 650rpm to about 2000rpm automaticly...Is this normal for adjusting timing?
    Default Re: 7M error code help
    Are you serious?
    You have the TPS disconnected and you're asking if there's anything you should check?
    Is there any (real) reason why it's not plugged in?
    I was saying the only thing we have touched is the plug as in unplugged it to remove head etc then plugged it back in...
    dont take me for such a fool!
    the word "had" is past tense...
    Oh, sorry ..
    Find the pins on the ECU for the TPS and check that the resistance sweeps properly, and that IDL connects to E2 when the throttle is shut.
    It's possible that a pin became dislodged, but it depends on how deteriorated everything is. Normally you would expect a better connection after replugging.
  1. 1990 MX-83, replace with 7M or 1JZ
    By MX83-maybe in forum Tech and Conversions
    Last Post: 20-11-2007, 03:16 PM
  2. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
  3. 7m and 1g injectors?
    By hypo23 in forum Tech and Conversions
    Last Post: 05-10-2006, 01:28 PM
