Results 1 to 15 of 23
Thread: Clutch alignment tool
    Junior Member Backyard Mechanic VasH's Avatar
    Default Clutch alignment tool
    Does anyone know of a good supplier for clutch alignment tools? im after one for a W58.
    thanks!
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    Default Re: Clutch alignment tool
    Give Adelaide Clutch Services a ring over here, or any of their distributors. Should be $3.91 from the last time i bought one.
    HP Guru Backyard Mechanic driftedmz20's Avatar
    Jan 2008
    any autoshop should also have them like supercrap auto or repco etc
    thanks guys ill ring around
    cannibalise a broken transmission for the input shaft
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Perth WA
    Quote Originally Posted by VasH
    thanks!
    A keen eye is all I use these days - make sure the friction plate is centred and then tighten pressure plate - job done.
    Jun 2007
    Use a set of verniers to measure the distance from the clutch disc to the pressure plate edge at 3 or 4 points around the clutch disc / PP.
    Doesn't work on recessed flywheels obviously....
    Victoria, Mt Macedon
    Recently I've just gone with something similar to Clint and abently. Fit all the bits and lightly tighten the pressure plate bolts. Then feel the gap between the edge of the pressure plate and the edge of the clutch plate at three spots around the outside of the clutch. Push the clutch plate around until they are all the same, then tighten the pressure plate bolts.
    It's worked fine, though can be a pain with 4puck clutches.
    Hen
    Ive got a twin plate os giken clutch going in so yea i think i need a tool, as a few people have said its a pain in the ass otherwise.
    Unfourtunatly i tried looking for a gbox to butcher for the input shaft but $10 for the tool seems alot easier.
    thanks all for the advice though!, rep to all. I will probably be posting about it this weekend asking for help lol as the install is happening this weekend
    Mar 2008
    i used a socket and extension!
    find the correct socket size that fits in your spigot bearing!
    put the first bit of clutch over and mark where it ends on the extension!
    then grab yourself some tape and wind it around the mark until you get a tight fit on your clutch!
    wack everything on and tighten! works first shot!
    S.A
    Hmmmmmm wont you need a splined tool ? IE to keep the teeth on the friction plates aligned.
    You may very well get the plates centered but if the splines dont match up the box aint goin in!
    Its been a while since i last used a tool but from memory it didnt have provisions to align the splines , just center the plate.
    Quote Originally Posted by 30psi 4agte
    Yep its a splined tool that im picking up
    Tasmania
    i got one from supercheap, was about $16 but works fine
    Quote Originally Posted by Clintoris
    Good luck in multi plate land
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    You'll need a splined alignment tool for a multi plate clutch, so your 'universal' style ones won't work at all.
    On another note, eyeballing a clutch in to position is possible, but the proper tool just makes the job that much easier to do.
    Terry
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. Should i buy a Clutch aglinment tool?
    Last Post: 18-04-2006, 06:41 PM
  3. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 12:14 PM
