Results 16 to 23 of 23
Thread: Clutch alignment tool
    Default Re: Clutch alignment tool
    The splined tool cuts down on the swearing and cursing as you find out under the car that the shaft doesnt quite line up.
    Junior Member Backyard Mechanic VasH's Avatar
    thanks for the info everyone ive found this brief guide to installing the clutch i have,
    http://www.zeroyon.com/index/content/view/59/47/
    but being fairly brief im still a little unsure as how to go about the alignment part after its assembled and the plates are offset do you just insert the tool through the first section then turn until it slides all the way through??
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Yup.
    10 char.
    Quote Originally Posted by Starfire
    Yup.
    10 char.
    does it have to be clockwise or anti clockwise or doesnt it matter?
    Doesnt matter, so long as the splines line up.
    S.A
    The thing is....... once everything is bolted you WONT beable to turn the clutch plates to align the splines
    This will all need to be done before it is bolted up tight + making sure the plates are centered.
    Best bet is to find a imput shaft off a w 57/58 and use that.
    Junior Member Domestic Engineer mic*'s Avatar
    ...Or a spilned tool thats already been bought.
    Any aid, is simply an aid to your logic - you know whats goto go where or you wouldn be apptempting it. Dont rush the important bits. Put a smear of grease on the tip of the input shaft so that locating the spigot bearing is easy as it can be.
    meh...
    Tallahassee, FL USofA
    Quote Originally Posted by 30psi 4agte
    There is no direction, clock or counter clockwise. Every pilot/spigot bearing has some play, so I like to move the shaft up&down left&right to make sure it's centered when things haven't been tightened, and are loose enough to shift around but hold that position until being tightened down.
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 02:18 AM
  2. Should i buy a Clutch aglinment tool?
    Last Post: 18-04-2006, 07:41 PM
  3. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 01:14 PM
