Results 1 to 15 of 17
Thread: 5K head on a flat top 4K
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Default 5K head on a flat top 4K
    Looking at you OC
    What sort of compression ratio would I be getting if I put a 5K head on a flat top piston 4K out of a KE70?
    Default Re: 5K head on a flat top 4K
    depends on any chamber work or porting
    decking of block and head
    gasket thickness etc
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Adelaide, SA
    Stock chamers, stock block and head; no shaving/decking. Standard ACL gasket. I'm putting it on regardless, just wanted to know what I'll end up with. Chambers on the 5K head are visibly shallower than the 4K one.
    from vague memory, 5K chamber is 16-17cc
    the usual 4K chamber is maybe 36cc? (you can calculate it easily)
    basically, you have half the combustion chamber = not good.
    Adelaide, SA
    Yeah, I did just work that out and may not be doing it regardless
    I believe my sums ended up somewhere in diesel territory @ 21:1
    I got 17-18:1, still stupidly high.
    Adelaide, SA
    North U-Pull-It was way more successful than Southern. KE55 5 Speed extension housing, and a decent 4K head. Took 1 3K and 2 other 4K head removals before I found one with little corrosion.
    vic
    Ive been curious on this for years , I was allways going to try a a late head on a early bottem end that i ran on LPG in a suzuki stockman but never did it . There easy to work on and at worst you just have to pull it off and stick the 4 k one on.
    Dave
    as you go from K to 3K to 4K, the head volumes get progressivle larger by abotu 3-4cc.. ie, 30-33-36 or something liek that.
    but the 4K and 5K dish piston heads are 16-17cc... which is just sooo wrong
    the valves are closer to piston, so there is not much room to dig out the chamber either.
    you can remove a few mm from the K heads, but might need to weld some of the galleries up to retain strength...
    then again..... 4k block, 1G pistons and rods, 5K head..... the 3mm down the bore of the pistons gives you 13.6cc...
    still high comp, low squish.. (are the 1G pistons dished? this might just work )
    Adelaide, SA
    All assembled now. 3K inlet and exhaust manifolds to get rid of EGR etc., stripped down KE70 carby that will hopefully still work.
    That extension housing swapped over no problems too OC
    Raastler Grease Monkey
    1GGTE or 1GGE ?
    dunno yet probably 1GGTE...
    what are the differenecs?
    vic
    Its also why as the motors chambers increased so did there fuel consumption.
    The best for sure was the KE 10 3K and K motors.
    5 and 7 K have shit economy and to make it worse i heard that the carby 7K has a higher comp than the EFI 7 K .
    Toyota allways have a habbit of de tuning there efi motors . i think 2TG and 18 RG were like this also.
    Dave
    but the bigger motors are in bigger cars...., heck the 7K is in a big van..
    the KE10's only weigh 720ish, so they have less mass to move around..
    Junior Member Domestic Engineer dfunkt's Avatar
    Apr 2007
    of the 3 engine's i've had in my ke20, the original tired 3k, a BHG 5k and a warm 4k, they all gave me less than 10L per 100km. the 3k was about ~9L and the 4k and 5k were ~9.5L.
    Owner of the Big Red Whale
    "i cant eat this because its too spicy" "i cant eat that because it has green stuff in it" "i cant eat that because its chilli soup with Blair's Ultra Death Sauce in it"... winge winge winge...
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 12:36 PM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  3. 18RG Timeline and Milestones
    Last Post: 15-03-2007, 06:38 AM
  4. Head gasket for 4agte
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-04-2006, 01:10 AM
