Results 1 to 5 of 5
Thread: Part nos for T50 gearbox
    .. Grease Monkey charged's Avatar
    S.A
    Default Part nos for T50 gearbox
    After some part nos for a T50 box.
    Need the parts no for the output shaft seal, bearings, synchro rings etc.
    I had a search but came up empty..
    John
    John
    Sharperto Racing IPRA Corollas
    www.sharperto.com.au
    Default Re: Part nos for T50 gearbox
    04331-14030 - Trans gasket kit (includes output shaft & input shaft seals)
    90365-30020 BEARING, x 1 - Front - Input shaft bearing
    90361-06047 ROLLER x 12 - Input/Output shaft roller/bearing
    90363-25017 BEARING, x 1 - Rear - output shaft bearing
    90369-30027 BEARING x 1 - Center - output shaft bearing
    33365-14011 KEY, SYNC x 3 - 1/2 synchro hub keys
    33368-20012 RING, SYN x 2 - 1/2 synchro’s
    33367-14010 RING, SYN x 2 - 3/4 synchro’s
    90365-30015 BEARING, x 1 - count shaft center bearing
    90365-20004 BEARING, x 1 - front countershaft bearing
    90365-20001 BEARING, x 1 - rear countershaft bearing
    33394-14010 KEY, 3&4 x 3 3/4 synchro hub keys
    33366-14010 KEY, 5&R x 3 5/Rev synchro hub keys
    33367-14010 RING, SYN x 1 - 5th gear sychro
    33363-14012 SLEEVE, T x 1 - 1-2 shift collar/synchro hub
    33364-14010 SLEEVE, T x 1 - 3-4 shift collar/synchro hub
    90364-37002 BEARING, x 2 - 1st & 2nd gear brgs
    90364-37004 BEARING, x 2 - reverse gear brgs
    90364-27003 BEARING, x 1 - 5th gear brg
    KE38 - 2TG
    MS65 - 1UZ
    It also depends on which box you have. The AE86 has different bearings to the TA22 and early TE72 box's. I have a list somewhere of aftermarket numbers for each as i just rebuilt my box and i was working for a bearing company so had access to their database listings. I'll have a look for the lists. But you should know some parts i couldn't get hold of, like the synchro hubs and some of the synchro keys. Bearings seals and sychro rings are easy tho.
    sorry thats for ae86
    KE38 - 2TG
    MS65 - 1UZ
    Here's the AE86 aftermarket bearing no.s:
    B130-141NRC3
    DG2563AZSH2C3
    F30BC06S8
    030-4
    04NUP0515NRC4
    04NUP0517C4
    30RUSS4C/40
    I'll post the rest when i find my reciept.
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 02:18 AM
  2. Need Help Identifying My Gearbox
    By AusRA28 in forum Tech and Conversions
    Last Post: 23-04-2013, 05:43 PM
  3. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 02:30 AM
  4. 1JZ-GTE Gearbox help required.
    By CrezBez in forum Tech and Conversions
    Last Post: 23-01-2006, 10:06 PM
