Results 1 to 15 of 23
Thread: Lexus IS200 / Toyota Altezza spherical bearings adjusted arms
    Mar 2008
    Moscow region
    Default Lexus IS200 / Toyota Altezza spherical bearings adjusted arms
    hello everyone.
    does anybody used spherical bearings suspension parts?
    I'm planning to produce a front lower arm for my lexus is200 with spherical bearing to castor adjustment.
    we're already produce one for test, but bearing what we use is a crappy one.
    i need advice - where to get a good spherical bearing with internal diameter 22mm.
    ideal will be spherical bearing rod-end with internal diam. 22mm with seals
    i've found one, but noone sell it here in Russia or international via internet.
    this is a german company Fluro
    D=22mm
    seals like this:
    Always in progress > > >
    Lexus IS400 UZXE10 wangan car
    Levin Coupe AE86 drift car
    Junior Member 1st year Apprentice boon280's Avatar
    Apr 2007
    S.A
    Default Re: spherical bearings and rod-ends
    Hi i use sphericals on my off road buggy front suspension i bought them from the states from a company called rod end supply, they were very good to deal with and very cheap and were super quick with shipping (6 days) try them.
    http://www.rodendsupply.com/RodEndSu...atalog_new.pdf
    Mar 2008
    Moscow region
    thanks for the answer, but they are all in inches sizes, in Russian as an Japan too, all in metrics.
    Apr 2007
    S.A
    e-mail them and ask for the size you want, they may be able to help as they dont list everything.
    Built! not bought Grease Monkey SYC02T's Avatar
    22mm is very close too 7/8 inch, for manufacturing they may be the same. ie nominal size v's actual size.
    Good luck, tell us how you go.
    If your not living on the edge,
    Your taking up too much space!!!
    teq Grease Monkey
    California
    Also, most rod-ends you can get a larger size than the bolt (or whatever is going into the rod end) and have the 'adapters' custom machined to the I.D. you want/need as well as the length necessary beyond the rod-end center section.
    Andrew
    Good suppliers here in Australia are Linear Bearings and Racer Industries. A google search should bring both of them up.
    Now - RA23-WRX
    Ive got a heap of Linear Bearings RMT series spherical bearings ill be using on my RA28.
    Expensive little bastards
    S.A
    yep linear bearings are the go but pricey.
    It cost me $780 odd just for the ends for my rear end
    Apr 2007
    S.A
    Quote Originally Posted by 30psi 4agte
    Jeez how many bearings did you buy and what size?
    sounds like you got ripped?
    Mine were about $80ea from memory.
    I needed 6 of them.
    Normal spherical bearings cannot handle shock loads so are not suitable for automotive suspension use (or dont last long).
    The RMT series im using will handle shock loads.
    I was told when i bought them that the Adelaide Uni SAE and a few V8 super car teams use the same ones.
    S.A
    yep that is correct MWP.... thats what im using and is the same as the super cars.
    I paid something like $65 per joint for 1/2 inch hole 5/8 thread ends.
    I needed 12
    Apr 2007
    S.A
    I bought 10 3/4 hole x 3/4 thread chromoly kevlar teflon lined heims with postage landed to my door for $30 each from rod end supply in the USA, been on the front of the buggy for a season now and still as tight as ever.
    oregon
    Hmmmmmmmm VERY interesting product!
    When I bought my Gita the pass side lower control arm was bent.... took it too an alignment shop and before I could stop them... they BENT the other lower control arm to compensate!!!!
    (2 red arrows in middle of page)
    I ended up having to buy BOTH!!!!
    boo50 - can you also make it with the stock mount?? That particular lower control costs about $135, and if it were adjustable... it would save some $$$$.
    What size should i use on the rear 4 link of my AE86? 3/4 or 5/8 thread and what size bore is best? I can make the spacers at work. I was thinking
