Results 16 to 30 of 74
Thread: Toyota VVTi Setups
    Default Re: Toyota VVTi Setups
    Purely VVTi function.
    Forum Sponsor Conversion King
    this is for me to argue with everybody
    3S Gen5 BEAMS (not sure if applicable to Gen4 Beams)
    36-2 home signal
    4-1 on the back of both cams but in different locations to work out where No1 tdc is.
    will measure later and report back.
    Note: both these pickups on the cams are variable to the crank therefore the ecu relies solely on the 36-2 to adjust the cam positions accordingly.
    linden
    This post is because you forgot the 1ZZ-FE and 2GR-FE and 2ZR-FE and 2AZ-FE
    Melbourne Victoria
    this is for edd for detonating his engine ,causing it to spin a bearing, RIP the hand grenade
    ps he wouldnt be told ,gets to angry and attacks to many people
    Penrith BC
    Quote Originally Posted by Celica RA45
    this is for edd for detonating his engine ...
    he wouldnt be told what? it hardly failed due to lack of vvti
    if i did what i was told glenn, thered be a TT 1uz in my engine bay, not a +130hp/L chunk of paper weight
    ../delete/ban
    tech moderator
    get over it you 2.
    Ed, dry sump it to ensure 0 chance of further oiling failure and you should be swet, but keep the rev limit abit lower than previous unless you plan on running a billet crank designed for the job.
    now back on the topic of VVTi
    the 1gz runs a 3 prong pickup on the back of the inlet cam (variable) with what looks like an evenly spaced layout ie 120-120-120
    i cant see anything down the front but will report back after removing the harmo to find out. i expect it to run a 36-2 but im wondering exactly how it will reference Tdc No1 as i cant see a seperate pickup
    GR
    Variable Cams
    Actuation
    Factory Sensors
    Cam Sync -
    Crank Trigger -
    Cam Position Sensors -
    AZ
    Variable Cams
    Actuation
    Factory Sensors
    Cam Sync -
    Crank Trigger -
    ZR
    Variable Cams
    Actuation
    Factory Sensors
    Cam Sync -
    Crank Trigger -
    Might also want to include which cams are actuated by VVTi and also how is actually works (oil control, trouble shooting info in regards to actually getting it to work) - much like what dori dori had to go though to get his VVTi setup working on the Soarer - link includes some info from Mos...
    I have found a general document on the development of the 2ZZ. It adopts a variable valve timing and lift system called VVTL-i. It operates under a single change over point between a low and high lift cam at 6000rpm, with the intake cam timing able to be continuously varied. Further details can be found in the document below (doesnt allow direct linking so download the one with the same title).
    Development of the High Speed Toyota 2ZZ-GE Engine (500kB)
    http://www.mmsport.com.au/Technical_Documents.php
    NZ
    Variable Cams
    Actuation
    Factory Sensors
    Cam Sync -
    Crank Trigger -
    Given the waste-spark layout, does it even need to know?
    how would it know where to start firing the injectors and trigering the coils if it cant figure out No1 Tdc? needs to have some idea where it is in the cycle but ill pull the D/S cover off later as the answer may lie there.
    linden
    Does it have sequential injection or batch? If the latter, with waste spark, it just doesn't have to care does it?
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
