Results 16 to 23 of 23
Thread: Crown tank to EFI
    south australia
    Default Re: Crown tank to EFI
    yeah. thats the pump, but its missing the mounting bracket that makes it run horizontal. that braket also has the sender for the gauge on it too......its bit hard to describe. ill try to find pics....
    Man i done a fair few of these pumps....i should be able to describe it
    My 1UZFE MS46 Crown wagon has a tank that is almost identical to yours. I am considering using a VS Commode setup. Just need to find the time to pull the car off the road for a week.
    User Conversion King
    NWA
    wouldnt a MS112/123 tank just bolt in?!?
    i thought the chassis' were nearly identical between all the crowns, and therefore wouldnt the tanks mounts be the same?
    just a thought
    hello
    Totally different.
    Jesse,
    Mate intank pump set ups are usually a pricey exercise due to the need to modify the factory Tank. If you decide to do one make sure you pick a pump that is up to the task. Being a N?A engine most should do the trick so pump size and fitment is your biggest concern.
    If you decide to ditch the intank idea and fit an external fuel system something luke this should work well.
    This is the same set up from a different angle:
    http://www.toymods.net/images/zoom2/...nd_filters.jpg
    Stitts should look much the same altho I think his is mopunted slightly differently.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Sorry to hijack the thread.
    Rod, is that set up you have noisy at all????
    Shane.
    Low rep 1st year Apprentice
    ok due to money and too much thinking and complications, im seeing if i can get the factory pickup fitting with a 1/2" fitting welded to it, and ill run external, that setup likes nice, neat too, also would be interested to know if its noisy, crowns are meant to be quiet!
    tough exhuast note is a exception of course.
    your setup looks great, when ive got the money if the surge is bad, i might go for something similar to that, and it would also be a lot easier to fit when i can get the car to the hoist at work for that kind of stuff too
    Shane,
    Mate with all the windows down and very light throttle you can hear the pumps but they are not obtrusive and the rear panel is not fitted on the inside of the rear qtr yet.
    You can hear them but they don't annoy me and there is always just turning on the stereo
  1. Toyota Crown MS53 Crown Custom Wagon
    By TheToyman75 in forum Tech and Conversions
    Last Post: 23-06-2011, 11:44 AM
  2. Toymods Crown Picnic Day-- Offical event
    Last Post: 28-10-2008, 06:18 PM
  3. Toyota Crown MS63 Custom Wagon Info
    Last Post: 28-09-2007, 12:31 PM
  4. Replies: 1
  5. External radiator header tank
    Last Post: 12-10-2005, 10:52 AM
