edit - was wrong see below
Just wondering if the MS112 Crown differentials have the same mounting points as the same differentials in the Cressida models.
RA23 - Twincharged
JZZ20 - Daily
No the Crown MS 112's have a normal differential with disc brakes so I was thinking maybe the Cressidas have the same type since they are related. I need a MS112 type differential for my 75 Crown and I don't want to buy the entire car to get one.
This type of differential is required -
the mx73 carrier I have sitting on my garage doesnt look like that, its definately IRS.
RA23 - Twincharged
JZZ20 - Daily
Cressidas aren't really related to Crowns except that they used the same engines in some models. As mentioned above MX73 and later is IRS, MX62 is live axle but E series (I think?) with 4-stud axles and I doubt it would have the same mounting points.
Norbie!
www.norbie.net
Like Norbie said, you'd want MX32 and 62. After that IRS. They're also 4 stud, drum braked and E series diff.
Just pop on to Classicrown and put a shout out for a whole diff. Someone will sell you one.
Tried Steve (crownman) on here?
for memory the MX62 series have 2 upper mounting points, the crown diffs as pictured above only have 1.
MX32 will be the same.- no go.
where are you located? talk to other people in the same region to see if they have come across a MS112 at the wreckers
hello
Hi guys, Thanks for setting me straight, I live in Emerald Qld and the Crownman does he has a business.
The crownman will do business with you. Just PM him.Originally Posted by 1975ToyotaCrown
Whats a PM
PM = private message.
