There is a second bracket that is bolted to the base of the compressor. These two brackets are connected via a long bolt that is used to move the compressor to tension the drive belt.
This next Pic shows the compressor with the main and lower brackets in place.
The unlabelled arrows in this pic show the four slots used to bolt the compressor to the main bracket.
And this pic shows the compressor raised to the highest position using the adjusting bolt. I think I have seen this method used on some other Toyotas. Possibly with M series engines.
**Looks like I lost this pic at some stage**
As you may have noticed there are two other mounting points on the lower bracket. As indicated in the second last pic one side is bolted to a bracket that extends from the engine mount and the other bolts to a AC specific alternator bracket.
The standard alternator bracket has a straight slot where as since the AC requires the bracket to be in a fixed position the alt. slot is curved to allow the alternator to adjust. The end of the bracket also has a slotted hole for the AC. The hole is slotted vertically to allow the compressor to move up and down for adjustment.
At the rear of the compressor is the final bracket that extends from the engine mount and also has a vertical slotted hole for the lower bracket.
.......one word of warning on this though is have the bolts on the bracket to the head loctited on as with the air compressor weighing as much as it does they have a tendency to work loose from the rocking of the engine.......i used to have air-con on my 18RG and they stripped one of the bolt holes cos of the softer alloy head and the hard steel bolts.......also caused a crack at the front of the head near the timing chain as it is thinner alloy there and once again with the heavier weight and the rocking of the engine.........don't ask me how much friggin around it was to re-weld the soft alloy at the front.......in the end I binned the lot of it.........made the car 10kgs lighter and I just wind down the window
