Results 1 to 4 of 4
Thread: Fuel Lines / Returns Which is Which KE70/AE71
    Feb 2008
    Arrow Fuel Lines / Returns Which is Which KE70/AE71
    Hi Guys
    See two pictures attached, one is the solid lines from the fuel tank (Assume) and the other the fuel pump on a 4AC engine.
    I need to get the two of these linked, the pictures describe what I think each are, Am I correct?
    Mike
    Default Re: Fuel Lines / Returns Which is Which KE70/AE71
    for the car
    the long line to the front of engine bay is charcoal canister
    of the two remaining ones
    big - feed
    little - return
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Feb 2008
    Any Idea on the fuel pump?
    not sure
    stick a hose on the one you think is the feed
    into a bucket of fuel
    run the pump
    the one which spits out the most fuel is the carb outlet
    then cover it with your thumb
    fuel should start going out the return instead when the main is blocked (over pressure)
    hth
  1. where do these vacume lines go on my 32/36 weber?
    By rob in forum Tech and Conversions
    Last Post: 05-11-2007, 10:36 AM
  2. fuel system
    Last Post: 02-11-2007, 01:02 PM
  3. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 02:05 PM
  4. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
