Results 1 to 10 of 10
Thread: 20v TPS? & MAP?
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Default 20v TPS? & MAP?
    I have the job of wiring up 2 silver 4A-GE 20valves, one with Haltech computer, the other with blacktop computer. Both with twin coils.
    The Haltech kit comes with its own TPS, and the previous technition thought this one had to be used instead of the original. (Also missing Haltech MAP sensor )
    So the original TPS (throttle position sensor) is missing, and the Haltech one does not fit, without spending a massive amount of time making an adapter or something.
    So has someone got a spare TPS for me, or will one off another engine fit the 20 valve?
    And do you think a generic MAP sensor (say, off a AE95) will work for Haltech or stock 20v computer?
    AE86 Tuning Life Backyard Mechanic Garth AE86's Avatar
    Sydney NSW
    Default Re: 20v TPS? & MAP?
    best buying the haltech map sensor
    pretty cheap from what i recall
    as for your other questions, i can't help sorry.
    Garth - 100% AE86 Addict
    AE86 - Levin & Trueno - The Legends Live On!
    'AE86' - Toyota Sprinter Trueno GTV
    "It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
    Try to get the Haltech TPS working.
    I think youll find itll save you a lot of time in the long run.
    Adapting a Haltech TPS to work on TB's ins't that hard. You really need access to a lathe though. On the plus side, the Haltech unit is much nicer than the factory one. It gives much more stable results and a nicer tune.
    Im currently using a 20v sensor, and have no issues whatsoever with it. The resolution of the sensor (albeit its a new one) is exactly the same as the Haltech unit when tested with a benchtop multimeter.
    Melbourne Victoria
    and the factory 1s are about 150 to 160 mark
    aren't most TPS and MAP 0-5V range?
    $150 odd for a factory fitting TPS aint bad.. not as good as a Farnell special but not bad for no fiddling
    how can a haltek tps be more stable
    i would thik a toyota one would be more durable or less chance to fail
    std toyota and nissan sensors shit on most aftermarket brands
    just get the 20v and use the red yell and brown wires
    map sensor is same as a holden vn v6 im pretty sure
    just try find a tps of a toyota that fits from an importer
    ring sss automotive in sydney they sometimes have some lying round
    i might have some in my junk but its too much hassle to check now
    Quote Originally Posted by sideshow
    Good point, it's also the same as a Camira (you can probably get a whole car for less than the cost of the sensor )
    Buenos Aires
    I donīt have experience with a Haltech, but any standalone unit that would like to be worth of being must have a TPS calibration function. These kind of devices are designed to be "universal", so using "any" TPS shouldnīt be a problem.
    With my Wolf, I used a Bosch TPS at first (didnīt find the right one) with and adapter plate and then I found the one that matches my ITBs.
    So, to sum up: TPS are "all" the same (electrically speaking), you must get the one that matches your shaft shape and mounting holes.
  1. Full-variable output TPS - what cars ??
    Last Post: 20-02-2006, 11:59 AM
