Results 16 to 18 of 18
Thread: Stronger AE86 rear end options?
    Nov 2007
    Default Re: Stronger AE86 rear end options?
    Be careful, not all the hilux models have an F in the front (looked at one in the selfwreck the other day that was stamped G,G on the plate).
    teq Grease Monkey
    California
    Quote Originally Posted by SharpTDI
    Forgive me if I am mistaken, but here in the US all 4age AE86 have the T series 6.7 rear axle factory. Is it different on your side of the water? I am not very familiar with the S series axle other than it being the 6.38" size and weaker internals.
    As for the upgrade, I will also suggest the 7.5. It is significantly more robust than the 6.7 and has a wealth of available LSD options, lockers, and spools.
    There are no spools available for the 7.5" F-series diff that I could find. Anywhere. If someone does know where to find one please point me that way because I want one.
    All USDM AE86 GT-S (yes w/4age) came with a disc brake 6.7" T-series rear axle (same as the JDM).
    The S-series that came in the ADM version is the USDM 'SR-5' rear axle, 6.38" drum brake axle.
    assassin- pure abuse will kill any gearbox and diff, regardless of strength i am not sure why people continue to rate gearboxes and diffs based on power instead of toeque but...
    True, unfortunately for me it was after how I figured out how to drift with very very slight clutch kicks... if at all. I just carried momentum for long sweepers or dori. Learning/basic stuff my t-series was fine for over a year.
    I also made it to the point I broke a pinion tooth, bent a spool (it walks like a crankshaft now) and twisted the splines on an axle all at the same time
    It had about 6 mo driving time, and probably a fair amount of abuse
    Andrew
    oregon
    T series can take SUBSTANTAILLY more torque when the crush sleeve is removed in favor of a non crush type sleeve.
    By The Witzl in forum FAQ
  2. AE86 rear coilovers into TA22?
    Last Post: 26-06-2008, 07:47 PM
  3. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
