Do you think you'll bother rewiring everything if its too much work to just put the key in?
The doors switches and modules are fed power by a 12v switched source from the ignition. The easy ugly way would be to just hack apart the wiring you have there add an inline fuse and feed it power directly from the battery so its always "live". You can go through the fenders. You'd have to do this on both sides for both windows. Then just pull the fuse from the fuse box so the hacked wiring thats still left there doesn't cause a short
To make it neat, you'd have to pull apart the dash to get behind the fuse box, and instead jump the feed for the power window fuses to an always live power source. But this would give power to both sides and atleast look OEM.
Either way takes work and proper wiring if you dont want your car to burn up, and from your post you dont exactly sound like the get up and do it type.![]()
