Results 1 to 9 of 9
Thread: Brake upgrade for ST205 gt4
    Default Brake upgrade for ST205 gt4
    Just wondering has anyone thought about a brake upgrade for a Celica GT4 ST205?
    Obviously would be running bigger rims that the standard 16s
    Default Re: Brake upgrade for ST205 gt4
    Personally, in order of ease of work and performace level.
    For a road car that can be used for track days and supersprints:
    step 1) Good pads EBC or Ferodo, braided lines and good fluid.
    step 2) Then I would swap to DBA 4000 series rotors as a straight replacement. DBA4560SL and DBA4560SR.
    or) Find a bigger diameter rotor of the same width, the DBA catalogue has all the dimensions of all rotors they make. Then make an adaptor bracket to move the OEM four spot calipers out. A ten millimetre increase in diameter makes a big difference in braking performance.
    The rotors off the JZA80 four pot caliper series Supra, a DBA4718, maybe easiest to adapt. They are 323mm dia (ST205--315mm), 30mm thick (ST205--32mm) but not as high overall 50mm as opposed to the ST205 at 59mm.
    or) If you are building an all out track car I'd look for a complete Brembo or Alcon or one of those Japanese rotor and caliper kits.
    Regards
    Rodger
    Last edited by Rodger; 14-07-2008 at 03:30 PM. Reason: changed supra id from engine to model as per DBA site
    forgot to say - Grp N Corolla rally car for Tarmac. Got bigger rims, so looking at bigger brakes
    Thanks, will look into that (and check about the rules)
    Well then for a Corolla and Group N would mean keeping the standard brakes perhaps only a change to the DBA slotted/cross drilled standard series rotors, braided lines and better pads are allowed.
    You do need to look into the rules. Targa rally rules differ slightly from CAMS Rally rules as they have some more classes with more modification freedoms, but I believe Group N is Group N in both forms of this motorsport.
    So are you saying you have ST205 GT4 brakes already on a Corolla?
    Regards
    Rodger
    Group NP corolla - one of the ex-TRD ones with a ZE122 bodies on the GT4 drivetrain. I was just seeing if there was an easy toyota parts bin that we may be able to sway but looking at the above I am not sure anymore
    Would have to look into slotted - cross drilled are a bit of a problem we have found in the past.
    Junior Member Chief Engine Builder Classique71's Avatar
    hmmss - the 205 brakes are the second largest options made from the factory outside of jza80 TT ones by memory - they shuld be highly suitable for your needs ? Whats bates running on his these days ?
    I know a few giys in europe have foen AP racing custom items but nheed a 17 to fit - and most bigger brembo items weve put on our gt4's have needed 17's as well
    Sounds to me if you want bigger stoppers its a custom 2 pc rotor - on a modified strut bracket , to take say a STI WRX brembo -
    Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4
    "Mongrel Garage - back on Aussie soil! "
    I agreee have a talk with the boys at Bates' shop here in Canberra.
    Regards
    Rodger
    Don't worry about that, we are. Just looking to see if there were any simple swaps out there. They might have something, still waiting on wheels as well.
    GT4 Freak, and Conversion King Squid's Avatar
    The Bates corolla's use ST205 brakes mounted on ST185 hubs, with milled down discs, 1mm off the mounting face and a 4mm spacer. I have a set in my garage to go on the 165.
    Not sure about the S2000's.
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    By The Witzl in forum FAQ
  2. Hoppers Stoppers brake upgrade vs Pug/Lux/Corona brake upgrade
    By ThaNav in forum Tech and Conversions
    Last Post: 04-10-2007, 12:31 PM
  3. Aw11 st205 GT4 Front Brake Upgrade
    By safeforever in forum Engine & Driveline Conversions
    Last Post: 21-06-2007, 10:25 PM
  4. AE86 Brake Upgrade - Here is what I did
    By Sprinter in forum Tech and Conversions
    Last Post: 01-02-2007, 10:26 PM
