Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 64
Thread: The Toyota Axle Database
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    Default Re: The Toyota Axle Database
    +rep for having a great idea and doing something about it..cheers
    Good stuff sunshine. However, the RA25 has a live axle and the LSD was only on the GT version of the car. The axle width, I beleive, are the same as the TA22 - but if you tell me where to measure from I'll do it and let your know the answer. Also, next time she's up on the ramps I'll take a piccy for you. I assume your email addy is on your net page?
    Anyway, +rep for you 'cos once (as I was led to beleive) you were quite pretty and you're a good advocate for the mighty 18RG. ... and of course the info you are collecting.
    seeyuzz
    river
    Oops, dunno why I put that down as IRS, well spotted. For now I'll assume the width is the same as other early Celicas, but if you could confirm for us that would be just super - measure from the hub mounting face. Pics would be awesome too, send them here.
    Oh and would you know the axle code for the non-GT versions? I assume it would be a T292 or something.
    would assume same as ra28 - T292
    Black Betty >HERE!<
    (\__/)
    User Conversion King
    NWA
    i just need to get batteries and ill have photos of several different toyota diffs.
    hello
    queensland
    congratulations on such a nice relational database. I provided some into early on to Brett which seems to have been included
    Just wondering if you have a live axle and a irs and both the same series are these interchangable in anyway?
    got 71? Grease Monkey cooter's Avatar
    wa
    OK, is TE71 the JDM model? And TE72 is the Aus-delivered model? Because I know the local ones are drum brake and no LSD.
    yeah te71 is jdm. forgot to mentionb ups on the database to. + rep for you
    craig
    Te71 Corolla Levin, Blacktop 20v
    Te71 Corolla Levin ex Rally Car 2tg.
    Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
    Ke70 Corolla 4dr Sedan
    Ae86 Corolla sprinter 4ac
    Corolla Feind
    Quote Originally Posted by 3sfe
    If you're talking about the diff centre then yes they are usually interchangeable but some modifications may be required in some cases.
    Offline Grease Monkey Toycrash's Avatar
    Finland
    Quote Originally Posted by cooter
    craig
    It's allso EURO spec model!
    But none euro spec had disc rear.
    It has 6.38" rear. Usually S314 axle code, some others seen allso.
    Only TE71GT has 6.7" and lsd was an optional but still with drums!
    Old toys for old boys
    Looking good, sunshine.
    I might have some more info regarding TA27 models and the ET Celica model - mainly TA20, TA22, RA21 stuff. I'll also see what the LT and ST versions of the RA25 had.
    I think only the 18R-G powered vehicles in the RAxx series had the F-Series LSD. That is, (for example) the 18R powered LT and ST RA25s did not have an F-series (much like the non-GT/GTV series of RA23/28). Anyway, I'll try and find more info and let you know.
    seeyuzz
    river
    tasmania
    the database is down, it won't work for me. just thought you should know
    beer me!
    Quote Originally Posted by joecoolmk2
    Pretty sure teh Norbie is in the middle of moving hosting..will prbly be up soon
    Yes that is correct, trying to get the new host setup properly this weekend.
    There are big things just around the corner, stay tuned people.
    OK it's back up and running at the new address:
    http://toyotaaxle.norbie.net/
  1. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 01:58 PM
