Results 31 to 45 of 64
Thread: The Toyota Axle Database
    Default Re: The Toyota Axle Database
    Norbie,
    RN2X G Series diffs are 1370mm rather than 1375mm...
    ([][][]II--LT--II[][][])
    Needs
    A, and B series diff codes...
    Show me a complete list of codes and I shall gladly do so! Most of the information I've seen so far conflicts.
    your mums an Carport Converter pato's Avatar
    umm.. i tried searching but i had no idea what to search for so this thread seems pretty close
    doing a manual 1jz conversion on my manual 1g supra. will the jza70 tailshaft t fit into my single spinner diff, from my ga70 ?
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    Assuming you're using the tailshaft which matches your new gearbox then yes the tailshaft will fit. All MkIII Supra diffs are externally the same, it's only the gearboxes which can be different (ie W58 vs R154).
    ahhh ok thanks
    all is good then
    Just a quick note, JDM AE86's have a 4.3 ratio T series. Example, the code I have here for a Levin GT Apex is T282
  8. #38
    Thanks, I've added the T282 axle code. Is the T312 code also valid?
  9. #39
    RA35 GT - F312 - Not sure on Width - Drum Brakes - Live Axle
  10. #40
    Thanks. The more info the better!
  11. #41
    Not to my knowledge. The only available options on the JDM AE86 were T282 or T283. I have read an article that mentions 4.1 ratios being available, (T284 and T285?) but I havnt confirmed this myself. The article states they are 4.1 LSD and non LSD options, but the codes they state ^^^^ are incorrect.......
  12. #42
    Offline Grease Monkey Toycrash's Avatar
    Finland
    If anyone is intrested, i measured AE95 read axle.
    From drum to drum 1466, Bare axlehousing 1325mm
    Axle bearing, 62*30*16(outside, inside, width)
    Axles have 25mm spline
    2.92:1 ratio, open diff, 6.7" T-series.
    Driveshaft bolt pattern 78mm cross and neares bolt to bolt 55mm,
    Wheel bolt pattern is 100*4
    Old toys for old boys
  13. #43
    Thanks, details updated.
  14. #44
    norbie your site is a bucket of ass see below
  15. #45
    Penrith BC
    HAXXOR'd!!...
    do'h
    hope you backed it up mate
    ../delete/ban
    tech moderator
  1. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 12:58 PM
