Results 1 to 14 of 14
Thread: Flywheels and Clutches for the mighty 2Lxx
    stunt dog Backyard Mechanic Esteban's Avatar
    wa
    Arrow Flywheels and Clutches for the mighty 2Lxx
    Anyone know if there are any differences in 2L Flywheels and Clutches over the years? What might those changes be?
    We're trying to organise a 2LTE into our hilux from a MarkII (xx90) auto.
    We currently have an 85 2L non turbo with a buggered clutch (1/2 reason the engine came out, and then we stumbled upon the 2LTE for possibly good money)
    My EPC tells me "not available" when I try and get a part number for the Mark II 2LTE flywheel when I select it (presumably as MarkII's never came 2L manual) so I can't cross reference the part or check the crank configuration until we get the motor.
    I'm worried the crank might have changed bolt numbers/ spacing etc, similar to the 4AGE vs 7A cranks... does anyone know?
    Also, we tried sourcing a 2LTx clutch from Coventry's and the guy asked, "which one? there are 7" ... and the prices were extortionate. Was planning on getting a 2LTx (tursbros) clutch regardless of engine conversion happening if they're (presumably) compatible... Any advice here?
    Thanks sexy toymod members
    wa
    Default Re: Flywheels and Clutches for the mighty 2Lxx
    Oh forgot to add, yes, before anyone gets excited, this thread is about Diesels... Move along, nothing to see here performance wise
    We've started making biodiesel, so the hilux gets extra love
    Apr 2007
    wilcannia NSW
    most of the 2LTEs i've seen have a poxy dualmass flywheel which is $$$$$. i would just use the NA flywheel and a heavy duty clutch. definitely check the flywheel. i have seen some success with 3L flywheels.
    2L-TE flywheel
    13450-54040
    You drive the EPC like your drive your car... I kids!
    wa
    Yeah, EPC don't like to be sideways
    wa
    Quote Originally Posted by briney
    Sweet. Thanks for the info, exactly what I'm after +rep as soon as I can... I've been a rep whore today it seems
    vic
    LN106 2.8 diesel flywheel AND clutch kit , done it many times before . dont get the dualmass one =Shit.
    Dave
    wa
    Thanks dave, so the 3L flywheel fits the 2L crank then?
    ps *lunchtime drinks rock*
    wa
    We're now the proud owners of the MarkII 2LTE too
    Quote Originally Posted by cambelt1
    Dave
    and you should be able to source the clutch kit on eBay
    and no, i'm not loaning you the flywheel out of my ute.
    vic
    Yep 8 bolt 3L flywheel for the 2LTE.
    Dave
    wa
    Ok so the 2L has a 225mm clutch on a 6 bolt crank/flywheel, but the 2LTE has an 8 bolt. The 2LTE it turns out is basically a 3L stroked to 2.4L. The head is completely different (so no bolty bolty for manifolds etc) as its cams with buckets as opposed to rockers in the 2L. This probably accounts for it being alot quieter.
    We ended up doing the following, due toe the possible future 2LTE conversion:
    $266 - 240mm 2LT HD Clutch Kit (Exide - Nicks Performance Clutch)
    - Clutch Cover, Clutch Disc, Spigot Bearing, Throwout Bearing
    $35 - Flywheel machining for Existing 2L flywheel
    - machined out to 240mm (NPC)
    $220 redrilling, tapping and balancing 2L flywheel to suit 2LT HD Clutch kit (Mendham Engineering)
    While that may look expensive, we can now bolt a stock 3L (2LT) flywheel under our clutch when we convert it, and it should all be apples. Total saving is $266 - 220, so it's heading towards wilbo scrouge territory, but nonetheless money is money.
    FWIW NPC want $375 for a brand new 3L flywheel, but we'll probably look for a second hand unit. Also we can still use the 2L flywheel for a normal 225mm clutch, however this will probably be sold along with the rebuilt 2L when we convert it.
    wa
    Update: The clutch rocks!
    Also, NPC's grinding/facing machine put a surface on our clutch that was 7thou out of flat. According to Mendham Engineering was about 4thou too much so they rectified it at no additional expense. I was worried at first as the surface had a lathed finish (as opposed to the rough finish from the flywheel grinder)...
    However, it works a treat :-)
    Mendham balanced the entire assembly too.
    I had to make a custom clutch slave rod to get the fork adjustment in the right spot too. No biggie though.
    wa
    Flywheel Redrilled, Re-dowelled, and Machined
    Balanced Assembly
    All Together (turns out same input spline as W58 too!)
  1. 3S-GTE flywheels & clutches sw20 gt4 etc
    Last Post: 03-07-2006, 08:56 PM
