Results 1 to 15 of 16
Thread: Whats the best sound deadening???
    Default Whats the best sound deadening???
    Hey guys.. I'm trying to reduce a little bit of road noise in my mx32 cressida . I was thinking of some under lay for the carpet and maybe something for the inside of the doors . What have you found to be the best ? Any infomation would be great . Thanks Steve
    Junior Member Backyard Mechanic DLA11D's Avatar
    Default Re: Whats the best sound deadening???
    Dynamat.
    Weighs a tonne, though.
    I found you can buy it cheaper in US (ebay) and ship it over
    1992 Toyota Hilux Extracab
    2JZGTE - TO4Z powered.
    1968 Toyota Stout Lite
    Work in progress
    Yeah . Thats what a couple of people have said . I might just have to bite the bullet and pay for the good stuff!!!
    What would one expect to pay for dynamat? Is it sticky backed or do you have to glue it down??
    The tractor Grease Monkey
    May 2007
    sticky backed, look on ebay us for it (its about $30 cheaper)
    Your local panel/paint supply shop will stock a sound deadening sheet. About 350mmx350mm square and about 4-5mm thick, self adhesive backing. It is a bitumous type product. I generally throw a half sheet into the door of each TA22 Celica I biuld, the doors then give that nice solid thunk when closed.
    I believe it is called sound deadening/anti drumming.
    cheers Chuck.
    MS51Crown Coupe,
    Junior Member Grease Monkey Rob KE25's Avatar
    2 steps I have used, to work together.
    1.
    I've used the same stuff ChuckLandwehr is talking about. It's like dynamat, but roughly half the price, and without the thin aluminium layer. That stops the drumming or 'tin sheet' sounds. Stops the sounds being carried along the metal, like a tin sheet.
    2.
    Then I have bought some sound deading foam from a foam/rubber distributor, which has aluminum sheeting on one side, adn I think open cell for most of its thickness. This is to reduce the dB by 'capturing' the noise, and absorbing the energy thoughout the foam. Comes in 5mm -25mm thick. 25mm thick is about $20 a metre. So not cheap. but seems to work well.
    Don't forget to make sure all holes in the firewall are plugged up properly, and door channels, window seals have good seals in them. I haven't used it, but a few guys have said underbonnet sound deadening has greatly reduced motor noise.
    Cheers, Rob.
    so which material would be best for which part of the car?
    Not claiming to be an expert on it, but any sheet metal (especially big long sections without bracing) I put alot of the tacky bitumous type stuff on. this was stop stop 'the metal wobbling and reverberating. Eg roof, door skins, rear quater panels. When I put it on, and then gave it a good knock with my knuckles to test the sound, it made heaps of difference- the sound stoppedd imedialtely. Not as much difference on the bumpy reinforced floor plan, but I still put it there to reduce undercarridge noise. A mates AE86 had the tacks stuff all over the firewall too, thicker than on the floor. So I did the same.
    I would personally put both on everywhere, thick on the firewall(25mm) , and use a thinner (10mm) foam under the carpet and in the doors.
    I put the foam and tacky stuff between the rear seat and the tank, and that greatly reduced the 2 fuel pump noises in the tank and diff noise.
    The whole area doesn't need to be covered with the tacky stuff- it is to just stop the noise
    traveling up and down metal.
    Junior Member Backyard Mechanic Sigmeister's Avatar
    As stated, Dynamat is probably your best bet if you can afford it. Look at buying a bulk pack or two for the best value for money.
    If you're a tight arse, you can get flashtac from Bunnings for much cheaper and does basically the same job. Its just not as heavy per m^2 as Dynamat.
    There are also paint on deadeners. The wheel well\underbody paint is good for that, but it stinks so i wouldn't use it on the inside of the car. There was a product called G-Spot sound deadening paint. It was grey and basically had no smell, was great for some interior panels that were difficult to cut sheets of dynamat for. 1L was about $40.
    Classic JC Quotes
    "A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster."
    "Usually, a Range Rover would be beaten away from the lights by a diesel powered wheelbarrow. "
    "The Mitsubishi 3000GT is about as sporty as a game of Darts."
    jaycar sell a dynamat knock off product too. alloy backed tar mat stuff.
    dunno if its what your after but you can also buy cans of spray on underbody stuff from auto stores.
    JZA70|R / 12.45 @ 111 mph.
    Clark rubber mate,I did my 22 for about $130 all up
    stuffed a shitload in the back seat aswell!
    -Just Alloy Radiators-
    www.alloyradiators.com.au
    whaddya call that stuff?
    edit: and does it work?
    i've even used camping mat foam once a couple of layers of that works well
    but echo RobKE25.. you want to add weight to thin panels (to decrease their frequency?) and then foam to absorb transmitted sound...
    migth be worth thinking about the flammability if tou will do any welding or put it in engine bay
    for the small weight penalty, i have no idea why people rip out sound deadening material..
    Thanks heaps for the advise!!!!!! Looks like a have a very busy weekend in front of me!!!
  1. removing sound deadening
    By 4agte in forum Tech and Conversions
    Last Post: 15-02-2007, 12:33 PM
  2. 1GGTE metalic sound pinging inside engine !
    By romelan in forum Tech and Conversions
    Last Post: 27-06-2006, 02:23 AM
