Results 1 to 6 of 6
Thread: AE82 4alc issue - one wet spark plug - runs like WRX
    ditty man Grease Monkey
    wa
    Default AE82 4alc issue - one wet spark plug - runs like WRX
    I have had this issue with the AE82 for couple months and i have just decided to find out whats up with it
    the problem I am having is that it sounds like its dropped a cyl.. it was fine driving one minute then next minute it ran like a dog
    now I have purchased a new rotor button and dizzy cap.. i have put new leads on it, changed the ign coil to another 82 coil and im still not having any luck with it..
    I checked the plugs and number 1,2 & 4 are dry and kinda sooty (expected) but number 3 is wet, I wipe it off and it looks like oil.
    I started the car up with number 3 disconected and it ran exactly the same. reconected number 3 and disconected 1, then 2 then 4 and it still ran the same...
    I checked spark on all 4 cyl and I am getting spark on all cyl!
    so put all plugs back in, raced the motor and stoped it instantly and pulled number 3 back out and it was still wet, all others were dry.
    wot.. the fark... is going on! could the dizzy be farked? or could it be something more severe like a screwed ring.
    Default Re: AE82 4alc issue - one wet spark plug - runs like WRX
    compression test .. will tell you if you've dropped a cylinder..
    if the dizzy has sparks on all cylinders then i doubt the dizzy is farked, but i've seen some strange things in my time so don't quote me on that
    wa
    il do a compression test tonight.. any idea on what pressure I should have for a 320 thou car?
    Modify is my middle name Grease Monkey Darola's Avatar
    hey there mate....
    have u put the wet spark plug into another cyl??? could be a faulty plug
    comp should be about 130-150psi
    try them out...
    also if u are going to get new plugs for it... ask for early v6 prado plugs.. i found they ran great in my old 4a... and alot of other motors ive used them for
    hope this helps
    Ed
    Eddie 0433 85 69 66
    wa
    how does 48psi and dropping sound on number 3 ROFL
    put a tea spoon of oil down the cylinder and compression test again. If you read significanly higher its going to be the rings, otherwise could be stuck valve etc.
    By The Witzl in forum FAQ
  2. 1J Gurus - spark plug advice
    By whatthe? in forum Tech and Conversions
    Last Post: 08-12-2010, 10:24 PM
  3. 7mgte intermittantly not getting spark
    By ra65 in forum Tech and Conversions
    Last Post: 28-10-2007, 09:29 AM
  4. 4age ae82 no spark or injection
    By hemi twofifteen turbo in forum Engine & Driveline Conversions
    Last Post: 21-06-2007, 08:03 PM
  5. ae82 twincam handbrake issue
    By simob in forum Tech and Conversions
    Last Post: 17-10-2006, 09:19 PM
