Get a 7M or a Nissan motor.
Hi, does anyone know if the 1 and 2JZ GTE idle stepper motors are the same?
I need one for a 2JZ-GTE and don't know if they are interchangeable.
Grant
Grant, you going to run an aftermarket ecu at all?
Not much can control a toyota idle motor.
600 Club Member: Toymods Large Member
MegaP00 - 7MGTE Skunkworks division
RIP - Nathan Dean (TA-022)
It will be running a Haltech. So if the Toyota one won't talk to it, what other options are there for the 2J?Originally Posted by BlackSupra
I asked about what people were using previously and it seems that most people aren't using one. Just crack the throttle a bit instead.
Alternatively, a simple 2 wire one that is programmed to open up to a certain temp or below certain revs should do the job.
Haltech can control them. Unfortunately the VVTi 2JZ has idle control built into the throttle body which is also electric.
I've since swapped over to an early style 2JZ plenum and throttle body but it was missing a stepper motor.
Does anyone have one for sale?
I have a 1jz one I think at home. If you find out if it is the same, let me knowI have never seen the 2jz one.
I've got a spare 2JZ-GTE non-VVTi ICSV here.
PM me a reasonable offer if you're still after one.
1JZ-GTE and 2JZ-GTE ICSVs are somewhat different and not interchangeable.
GSE20 IS250 - daily
UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
Ford XF Falcon Idle Speed valve is the one of choice for Autronic users.Originally Posted by AE86slut
So haltech controls VVTi now?
Manny, i'll let you know in the next day or two if i need one. Cheers
Blacksupra, the Haltech can control the idle motor very well (close to factory according to my wiring guy) and we will be working on the VVT-i control.
I wasn't keen on the Ford unit as i want to keep it as clean (factory looking) as possible.
Well before the twins go on that is.
Cheers guys
Grant,
Keep us informed re the Haltech and the VVTi control. It would be a real shame to not be able to use it all because of the ECU choice.
I was under the impression Haltech could switch a VVT set up but not VVTi. Pretty sure that is still only available with the Motec or Autronic SM4 Labels ???
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
*signing up to thread* I too was under the assumption the Haltech couldn't control the infinetly variable timing, just the standard VVT switch stuff. I too thought only the Motec or Autronic models could control it properly. Will be interesting.
cough"microtech dont need one"cough.
cough"idles perfectly" cough
8.3 et PB 169 MPH PB
Its still early stages with the VVTi control through the Haltech.
I'm more than happy to have Haltech use the car as an R&D mule.
