its cool, i spent the last 3/4 of an hour searching, isent available seperately- DOH!
if i could get these made up would anyone be interested? i have a mate that works at an engineering joint and i may be able to get them made up on the side?
hey guys i need some help, im in the middle of swapping my shifter on my spare gearbox to the rear mount position and want to re-bush the shifter while im at it (mine are quite worn)
the blue insert is the bush im after, toyota are trying to tell me it has to be brought as an assembley and that that bush isent available by its self? surely it must be, does anyone have the part number?
Toyota AE93 Corolla 20v Silvertop
BF Mk II Xr6 Turbo Ute (tickled to 316kw)
Datsun 180sx turbo
Forester GT
Datsun 180sx turbo
Forester GT
I'd make my own so I'm not interested, but delrin might be a good material.
i was thinking a piece of billet alloy? easy enough to get off cuts that will be big enough to make theseOriginally Posted by af300e
Datsun 180sx turbo
Forester GT
True, easy to find. But you might be surprised to find that it doesn't last as long as plastic might in that application and it would probably thrash out your stick bush.Originally Posted by RA40-Rossco
You can always try it.
yea true hadent thought of that, so u reacon dilrin/nylon would be the go?
Datsun 180sx turbo
Forester GT
I'd give the delrin a go. I've machined a set up for swing bushes in a mates dirtbike and I tell you, they cop a dead set flogging and take it well. Smear of grease every now and again (only because they live in mud/water and occasionaly the carby overflow leaks fuel into the area).
Should last a lifetime in that posi.
There's a thread in the for sale section for replacement bushings for this. They require you leave the outer steel ring of the bush in place & glue it in. I have a spare kit I didn't use if you're interested.
I ended up making my own bush out of alloy that replaces the whole , which was very easy to do, but it's only been in for a week so I don't know how well it's wearing.
shoot me a PM with what you want mateOriginally Posted by BigWorm
Datsun 180sx turbo
Forester GT
