Results 1 to 11 of 11
Thread: 18RGEU Plumbing Q
    GO Grease Monkey zuludan's Avatar
    Jul 2007
    Default 18RGEU Plumbing Q
    Does anyone have a map of hoses and lines for the 18RGEU, I have not idea where all the hoses go and end up. Vac Lines and Etc... I can not find any good pictures of the 18RGEU......
    Any help appreciated.
    RA23 Celica - 18RGU.
    Learning the art of car restoration
    Two Kids + Two adults + Two Cats in one bed.. INSANE
    Default Re: 18RGEU Plumbing Q
    Check the 18RG tractor thread, there were photos put up by the Witzl quite some time ago with full explainations.
    Jul 2007
    See below double add
    Jul 2007
    I have looked at threads but my ECU is very different to the ones pictured.
    Any help would be appreciated
    What ECU are you running?? Most modern ECUs can dispense with a lot of the factory stuff (which was because the ECU was based on resistors etc to determine a 555 timer frequency etc)
    First photo:
    E fuel return to the tank
    F goes to plenum
    Second photo, fuel supply from the pump
    Third photo, I am blocking off for mine as it won't be necessary
    Fourth photo, they are explained I believe in the 18R-G thread
    Fifth photo, goes to the throttlebody (either water outlet, the other water outlet on the throttlebody goes between runners 1 and 2 into the inlet manifold flange) I will not be using this on my car.
    Jul 2007
    Plenum ?????????????? What is this ....
    Any ideas on A B C..
    I am running Factory ECU. Also there are two hose outlets on the water temp housing where do these go ????
    can't tell you about factory vacuum plumbing, I am ditching all of mine. Plenum is the big box between the throttlebody and the runners. It has EFI embossed on it.
    Jul 2007
    Where does F go on the Plenum. I Have worked out C it goes to water housing and the other side goes to the dizzy.
    A little bit of searching goes a long way...
    http://www.toymods.net/forums/showth...&highlight=18R
    This thread, turns up these diagrams which should help you piece it all together!
    http://www.users.on.net/~csharman/docs/18rgeu.pdf
    This should be helpful. Id reccomend saving and printing that PDF file.
    Jul 2007
    Thanks Guys, Thanks Spectre for pics
  1. 18RGEU dizzy question
    By RA23 in forum Tech and Conversions
    Last Post: 22-03-2008, 07:45 PM
  2. 18rgeu dizzy issues.
    By Omegaman in forum Tech and Conversions
    Last Post: 15-12-2007, 06:41 PM
  3. 18rgeu + TURBO
    By kristian in forum Tech and Conversions
    Last Post: 07-09-2007, 10:01 PM
  4. 18RGEU conversion help
    By dale30 in forum Tech and Conversions
    Last Post: 01-11-2006, 07:06 PM
