Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 104
Thread: why NOT to put a 1j in a hilux.
  1. #61
    Default Re: why NOT to put a 1j in a hilux.
    just under $1500 all up..
  2. #62
    actually it was just over $1400
    spend some more money/time yesterday, new shocks.... between the brakes, lower profile 'sporty' tires (which have been sitting around for 3 years now and are hard as) and the shocks.. it has completely transformed the thing to drive...
  3. #63
    wanker Backyard Mechanic MS-75's Avatar
    Righto-those discs look just right for an upgrade on the Crown.
    Cough up dude-what type are they!
    Diameter?
    Thickness?
    Sean
    [email protected], WSID, COMPAK ATTAK, MAY 2006
  4. #64
    They are 300x28 DBA 504's i believe... basicly falcon disks (checks the dba cattledog) yup, BA falcon.. 298mmx26mm
    hard bit is that they are on custom made hubs.. and funky brackets to make the calipers mount up.
    got the kit from hoppers stoppers www.hoppers.com.au
    knowing you, you can probably just knock some up
  5. #65
    they also do a 330mm version.. they are the disks off the FPV's i'd say.. but i suspect you wouldn't want those for the same reason i didn't... they need a minimum 17" wheel...
  6. #66
    Another reason TO put a 1j in a hilux
    and doing it incredibly easy... it also gave it a bit of traction
  7. #67
    bahahaha, very nice
    QUICKEST 1JZ'S IN OZ
  8. #68
    Rosewood
    did you look into the 4piston upgrades from the 4x4? I'm curious in how 'custom' you went with getting that brake package installed.
    Very nice progress so far !
  9. #69
    basicly the 4wd calipers would be nice.. but the disks wouldn't fit.. ever... so i needed custom hubs.. this was a bolt on kit.. i just wanted it to go on and work.. so i was happy enough to pay the cash
  10. #70
    Rosewood
    Quote Originally Posted by SL666
    care to ellaborate why they wouldn't fit?
  11. #71
    n.s.w
    have u thought about cutting your support and putting the radiator in front support i do it for 308 in hiluxs
  12. #72
    lance: 4wd hubs are completely different.. and 6 stud...
    AE71: the top of the support was cut and bolted back in, i didn't want to hack out the structural looking part lower down unless i was going to get a much bigger radiator in there.. it will happen when the excel one is no longer enough.
  13. #73
    Another reason not to put one in ...
    15.6L/100km which isn't that bad considering how i drive it.. but it works out to be about $22.75/100km and that wasn't even 98... just PULP
  14. #74
    After many trials and tribulations, my hilux is now engineered and road legal, the lokka centre is going in tomorrow, and boost controller on the weekend, then im looking forward to driving it around for a while before i go too silly
  15. #75
    Junior Member Domestic Engineer 1200det's Avatar
    What sort of Lokka centre are you using ?
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
  1. changing the gear ratio's in hilux diff.
  2. Alloy Trays on Hilux/ Cruiser/ Hilux 4 door
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-03-2006, 06:54 PM
  3. hilux caliper comparisons?
    By AE25 in forum Tech and Conversions
    Last Post: 05-12-2005, 06:04 PM
