Results 16 to 20 of 20
Thread: 4agze coffs and farts after bit of spirited driving
    old lurker Grease Monkey
    Default Re: 4agze coffs and farts after bit of spirited driving
    hmmm
    but very doable haha
    ill see if i can do that on the weekend
    fear the chicks car
    ever thought of seeing if the ECU shows any codes?
    Oberst Koi-Master Backyard Mechanic
    If no scoop then use some washers on the bonnet hinges to raise it up a tad, atleast get some more airflow happening. I ended up putting the scoop on because I knew it'd be ages before I sorted out something proper and bonnets aren't that expensive .
    Junior Member Automotive Encyclopaedia Nim's Avatar
    First, try without the bonnet. If it's fine, then you KNOW it's a flow issue.
    Daily: DC2 Integra VTiR :: 96kw @7300rpm - 132nm @6300rpm
    Techno Toymods | Beninca Dyno Day Results 10/9/05 | GOR Cruise '06 | My Photography and Illustration
    hahaha yeah spark plugs are rooted
    2 had been replaced sometime and 2 were rusty as
    the two rusty ones had 2.5mm gaps and the other two had slightly less but still melted
    set all plugs back at 1mm and gave it a good hard thrash and no coughing no stalling
    YAY
    they were ngk BCPR6EP-N plugs
    what plugs do u other 4agze'rs use ?? any recommendations ?
    i got a bit of money so im thinkin iridium ngk plugs
    fear the chicks car
