whatever size is required to ensure oil pressure is not >60psi at max load/pressure?
I spoke to Garrett about whether i need an oil restrictor for my turbo (HKS 2540) and got two answers.
when i first rang up to identify the turbo they said if oil pressure is over 60psi then i would need one.
its a journal bearing turbo but my motor (4age 100kw) will put out +60psi when revving.
i bought a restrictor from motorsport connections but its only 1mm.
Then I rang Garrett back to ask what size i should drill it out to and then they said that i didn't need one.
I'm pretty sure i do because if i drive it hard oil will leak out the seal and start burning on the housing.
So i guess my question is; what size do i drill out this restrictor to?
previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUXE
current:-> 06 BF XR6T, MY13 ISUZU D-MAX 4X4
i pulled three hundred rocks from the land to build my house
i walked quiet through the forest like a tiny quiet forest mouse
the oceans will rise
please stand by the shore
You could try ringing GCG turbos.
http://www.gcg.com.au/
or even email them.
I found them helpful when i dealt with them
its not a rear oil seal that is your problem here is it? -- you have had problems with oil leaking in the past?
When i bought my 3540 it came with a restrictor that sits in the core. It just slips in where the screw in supply fitting goes.
i think its the front seal.
http://www.toymods.net/forums/showthread.php?t=20467
http://www.toymods.net/forums/showthread.php?t=22498
Some good stuff...
CheersOriginally Posted by 30psi 4agte
ha ha ha..... + rep
When i saw this thread
I thought to myself hmmmmmm......... i used to know what the flow rates were !! because i worked it out when i switched turbos ( bush to roller )
I forgot i had posted it on here..![]()
Now aint that somethin.
