Might have been easier to strip out the existing PCB and fit a simple momentary switch behind the red button.
What was it worth?
Okay I got my hands on one of these and I pulled it apart tonight to find out the circuit layout
These things aren't cheap for a push button but It looks like there is something to do with the immobilisers built into these buttons are there are some terminals marked Ant1 and Ant2 and the sticker on the side of it says, "Amplifier, Immobiliser"
Also on the side is 5Vdc, 100mA so I assumed the LEDS on this run at 5V.
Front view, the green LED on top is actually a Red/Green bi colour LED
Inside there is the following circuit board. and I found the terminals on this side related to particular LEDs
When I applied +5V to these terminals the front LEDs worked
So in all the pin layout if your looking from the back of the button is as follows.
The two common pins, 6 and 8 are directly connected together at all times and are the -ve connection for the LEDs as well.Code:Pin layout is shown by the pin numbers '1' Not Sure 1 2 Push Button Connection 1 Red Bi Colour LED 3 Green Bi Colour LED 5 6 Common for Push Button and LEDs TRD Back light 7 8 Common for Push Button and LEDs Not Sure 9 Not Sure 11 12 Push Button Connection 2 Not Sure 13
When the engine start button is pressed in, pins 3and 6 are bridged together. As are 8 and 11
WSID: [email protected] (Weak) : Wakefield 1:16.1 Racechrono
What was it worth?
Daily: Toyota '05 Rav4 Sport
if you're interested in one email me michael.pitt @ lexusofbrighton.com.au and i can chase you one up at dealer costOriginally Posted by MWP
i pulled three hundred rocks from the land to build my house
i walked quiet through the forest like a tiny quiet forest mouse
the oceans will rise
please stand by the shore
oh, these are basically a "Pivot" start switch right?
they have same features and probabyl same cost
(same as the TRD gauges are DEFI)
look for a PIVOT start switch guide
liek this maybe? http://www.pivotracing.com/product/SSK
manual
http://www.pivotracing.com/files/199...aded/SSK-e.pdf
edit: apparently not.. they are just prettier stock part...
oopsExchange switch unit assembly. Painted in matt red.
*Only for vehicle equipped with push start switch.
*Only for vehicle equipped with smart entry system and start system.
so what does ti do in stock situation? talks to ECU and?AURIS 06.10- NZE15#H/ZRE15#H ※
BELTA 05.11- NCP96, SCP92 ※
BLADE 06.12- AZE154H, 156H
CROWN MAJESTA 06.7- UZS18#
CROWN 05.10- GRS18# ※
COROLLA AXIO 06.10- NZE14#, ZRE14# ※
COROLLA FIELDER 06.10- NZE14#G, ZRE14#G ※
ESTIMA 06.1- ACR5#W, GSR5#W
ist 07.7- NCP110, 115, ZSP110
RAV4 05.11- ACA3#W ※
Vitz 05.2- SCP90, KSP90, NCP9# ※
well, at least the TRD light switch goes to headlight power![]()
