Results 1 to 8 of 8
Thread: oil feed restrictor size
    Junior Member Backyard Mechanic jono's Avatar
    Jun 2008
    Question oil feed restrictor size
    I spoke to Garrett about whether i need an oil restrictor for my turbo (HKS 2540) and got two answers.
    when i first rang up to identify the turbo they said if oil pressure is over 60psi then i would need one.
    its a journal bearing turbo but my motor (4age 100kw) will put out +60psi when revving.
    i bought a restrictor from motorsport connections but its only 1mm.
    Then I rang Garrett back to ask what size i should drill it out to and then they said that i didn't need one.
    I'm pretty sure i do because if i drive it hard oil will leak out the seal and start burning on the housing.
    So i guess my question is; what size do i drill out this restrictor to?
    previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUXE
    current:-> 06 BF XR6T, MY13 ISUZU D-MAX 4X4
    Default Re: oil feed restrictor size
    whatever size is required to ensure oil pressure is not >60psi at max load/pressure?
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    You could try ringing GCG turbos.
    http://www.gcg.com.au/
    or even email them.
    I found them helpful when i dealt with them
    S.A
    its not a rear oil seal that is your problem here is it? -- you have had problems with oil leaking in the past?
    When i bought my 3540 it came with a restrictor that sits in the core. It just slips in where the screw in supply fitting goes.
    Jun 2008
    i think its the front seal.
    http://www.toymods.net/forums/showthread.php?t=20467
    http://www.toymods.net/forums/showthread.php?t=22498
    Some good stuff...
    Quote Originally Posted by 30psi 4agte
    For example a bush bearing turbo requires approx 2.5l per min and a BB turbo doesnt need as much requiring 1-1.5 L per min.
    The way to check your oil flow capability is to pull off the line before the turbo and place the line into a measuring flask of some sort. Then start the car and run for 15 sec. Measure the amount of oil pumped out and times it by 4 to get the amount per min.
    S.A
    ha ha ha..... + rep
    When i saw this thread
    I thought to myself hmmmmmm......... i used to know what the flow rates were !! because i worked it out when i switched turbos ( bush to roller )
    I forgot i had posted it on here..
    Now aint that somethin.
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Previous Rides: JZA80, GA70 GT, RA63 GT x2, TA61 GT, TA63.
  1. 1UZ-FE Injectors - top or side feed
    By taz_rx in forum Tech and Conversions
    Last Post: 14-06-2007, 06:11 PM
  2. Toyota Side Feed and Top Feed Injectors
    By TA22 1MZ in forum Tech and Conversions
    Last Post: 26-03-2007, 07:05 PM
  3. 2JZGTE Tacho Feed
    By BMWTurbo in forum Tech and Conversions
    Last Post: 14-03-2007, 11:06 PM
