Results 16 to 30 of 42
Thread: Installing LSD Into G Series Live Diff
    Default Re: Installing LSD Into G Series Live Diff
    LeeRoy, Thats exactly what i assumed when doing this... And i also checked any existing backlash before swapping the single legger out, and tried to improve slightly on this. I think i have, but i'll double check to be safe...
    Fixeruperer,
    Late model hilux...
    Jase
    JZA023
    perth
    ah ok thanx man, did you shim the lsd up to make it tighter ?
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    hey,
    I installed my lsd myself it was easy but then again it was an f series diff housing. It only had spacer shims on the sides and there were no adjustments to be made. I would be taking it to a professional to get it checked.
    May 2008
    is that diff in the pics a LSD..it looks so much like my G series 4 pinion Open diff
    1992 - JZA70 STOCK - SOLD
    The first pic is of a open center, the later pics are of the LSD...
    No i didnt tighten them up, i left it original as they where from relatively late model hiluxes, so hoping they are still pretty tight... Doesnt need much, the car weighs nothing compared to a hilux...
    Jase
    JZA023
    Feb 2008
    Quote Originally Posted by GA70H_92
    Exactly what i thought...the second one looks like the open diff I took out of mine. It might have been an lsd since it did spin twins when the car was packed full of people, and just singles when there was no one in it, any way it was fair shit.
    Jun 2007
    This is a good guide to rebuilding a G series diff http://www.4x4wire.com/toyota/tech/gear_setup/
    You use stuff called bearing blue to check the mesh pattern. It can be bought from any place like Repco , Motor Traders etc.
    Can someone confirm if what ive installed is an LSD or a Open Center. My center looks nothing like the ones in that pic...
    But it also looks totally different to my old open center... I'll be pissed if its open though, as i bought two of these as i was told they were LSDs...
    Jase
    JZA023
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    from what i have seen and been through. you shouldnt be able to see any of the teeth in the centre. it should look like its a clossed unit. what car is out of if you know.
    good luck mate
    cheers mat
    now withdrawn
    Supposedly a late model hilux...
    Thanks matt
    Jase
    JZA023
    Quote Originally Posted by SillyCarS
    yes, it is the same as mine
    it isnt a torsion lsd though
    What types of LSD where there? Torsen and...
    Cheers man,
    Jase
    JZA023
    Cheers man,
    Jase
    toyota ones are torsen and clutch
    yours looks like a torsen
    now withdrawn
    May 2008
    My 4 pinion open centre is indentical to yours.....and your old one looks like a 2 pinion....
    when you look inside those holes do you see a whole bunch of gears?
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  2. RT132 Corona - T Series, diff noise?
    By bnicho in forum Tech and Conversions
    Last Post: 27-07-2006, 11:18 AM
  3. G series diff database
    By bansheebuzz in forum Tech and Conversions
    Last Post: 01-05-2006, 10:36 PM
