Results 1 to 8 of 8
Thread: How to remove the brake line flange nipple form your calipers to fit braided lines
    Jun 2008
    Exclamation How to remove the brake line flange nipple form your calipers to fit braided lines
    I have found very little info on this so here it is!
    If you want to fit braided lines to your brake calipers, you need to remove the flange nipple from inside the calipers to accommodate a banjo bolt.
    http://img515.imageshack.us/img515/4200/p6110993mw8.jpg
    http://img265.imageshack.us/img265/3817/p6110996aq1.jpg
    http://img175.imageshack.us/img175/9907/p6111000jc7.jpg
    http://img360.imageshack.us/img360/583/p6110999tu4.jpg
    This is a fairly easy way to do this using a few simple tools. My calipers were already dismantled, but I'm sure you can slightly modify the procedure for calipers that are still bolted together.
    You will need a hammer, pliers, screwdriver, 2x small self tapper screws and a drift (I used an old 6 x 60mm bolt).
    http://img387.imageshack.us/img387/521/p6111004px0.jpg
    http://img387.imageshack.us/img387/1500/p6111007gj6.jpg
    The self tapper screws must fit tightly into the centre of the nipple, but not too tight. Screw one into the back by twisting back and forth until it turns quite easily. You need to screw it in about three threads and then back it out to about 1 1/2 turns. Make sure you can remove it quite easily.
    http://img511.imageshack.us/img511/9149/p6111005ic5.jpg
    Repeat this procedure for the front so that you have a screw in each side of the nipple.
    http://img365.imageshack.us/img365/1091/p6111014vw7.jpg
    Now take your drift and GENTLY tap the rear screw until the nipple pops through.
    http://img365.imageshack.us/my.php?i...6111010iz0.jpg
    http://img80.imageshack.us/img80/1738/p6111011gn8.jpg
    Remove the screw from the back. You may need to push the nipple gently from the front so that you can unscrew the back.
    http://img292.imageshack.us/img292/3286/p6111012cs4.jpg
    You should have enough of the front screw protruding to grab with a pair of pliers.
    http://img185.imageshack.us/img185/1386/p6111015ue8.jpg
    Now pull. Shouldn't take too much effort.
    http://img401.imageshack.us/img401/8783/p6111022rj0.jpg
    There it is. Make sure you clean out any stray metal shavings with compressed air. Try not to wipe in the bore with a rag because the metal shavings may scratch the polished surface.
    http://img401.imageshack.us/img401/1796/p6111021yq7.jpg
    Good Luck!
    Grotty.
    Two-smoking barrels.
    Forum Sponsor Conversion King
    Default Re: How to remove the brake line flange nipple form your calipers to fit braided lines
    or the other option is to shorten and countersink the bolt to suit, much quicker and easier to do and lets you bolt the std gear back in place if you ever need to.
    getting the correct lines made up would also help but doesn't happen as often due to price.
    good info though
    linden
    Couldnt you just drill it out?
    You wouldnt be able to keep the flange, but it would be a lot easier.
    Yeah, just shorten and countersink the bolts, MUCH easier. Means you can always use either option.
    Jun 2008
    linden
    It is never a good idea to shorten a banjo bolt. It may even be illegal???
    You can't drill out the nipple because it is only lightly pressed in, not threaded (see link below). The drill bit would just grab it and both would spin. Possibly when this happens you could then pull it out, but you couldn't use it again.
    Using the method I described, the nipple comes out whole, as shown here:
    It can easily be replaced if you ever want reinstall the original lines.
    Grotty.
    Quote Originally Posted by grotty100
    Grotty.
    how do you figure?
    provided you only shorten it the amount needed then there is no problem. it would have the same if not more thread than the std fitting which seem to have 3-4 threads missing before the inverted seat, therefore i see no difference.
    done it to over 30 different cars and havn't had a problem yet. and it only takes 5mins.
    linden
    Jun 2008
    how do you figure?
    done it to over 30 different cars and haven't had a problem yet. and it only takes 5mins.
    linden
    Removing the nipple only takes about 5 minutes as well (unless you're taking photos), so yes I see no difference too........
    I personally prefer to remove the part, but hey, we're all entitled to our own opinions.
    Grotty.
    Jun 2008
    Here's some photos of the braided lines fitted to the calipers:
    Grotty.
    By The Witzl in forum FAQ
  2. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    Last Post: 12-07-2019, 05:11 PM
  3. break upgrades/ta23
    By buztoy in forum Tech and Conversions
    Last Post: 14-10-2006, 08:00 PM
  4. Brake line issues, Line above master cylinder
    Last Post: 08-09-2006, 12:50 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
