I'm going to hazard a guess it's not actually the pump, or fuel side of things.
I'm going with an electrical design issue.
Redo all of the wiring with brand new, and THICKER wiring.
Particularly run an earth straight to a CLEAN spot on the chassis (For testing, even throw it straight to the battery!) but make sure you have sufficient sized cable.
I'm hazarding a guess as you're running the pump, the wiring is heating up, which causes an increase in resistance, which gives you a voltage drop at the pump, which drops off your flow rates...![]()
