Welcome to toymods!
i think you are our first france poster? (i was over there last weekLes Emibiez was cold!)
sounds like you have a good plan in place.
not sure on internals.. one of the T guys will say/
probably don't need to reduce comp for low boost, as long as mixtures and timing is fine. 9:1 should be ok.
of course it also depends on what fuel you will use? (octane etc)
usualyl HG is slightly bigger than the cylinder, and 86 is only 0.5mm radius difference... 2mm thickness probabyl not needed.
fro ECU, i think you are better off starting with MS or MS2 (MS1 with MSnSE code, or MS2), but you will need the ignition control to provide spark retard. you can use commercial ECU's as well, but no point trying to adapt 2TG or 4AG ECU and then have to change when you go turbo anyway.
if you have manifold already, then just build with turbo.. if you are worried abotu tuning, just wire/fix the wastegate open so it doesn7t boost, and play with fuel and spark first, then let wastgate do it's thing and continue tweaking the tables.
with MS, all you need is coolant and air temp (almost any are ok), the MAP is inside the MS, you need manifold, injectors, fuel pressure regulator EFI fuel pump and EFI fuel filter (return line to tank as well), throttle body with variable TPS (not switch type)... and O2 sensor.
ignition.. you can use the stock dizzy with MS to provide controlled spark, or you can use stock dizzy with a different kind of pickup (crank, flywheel etc)...
O2 sensor can be any generic 1 to 4 wire jobby... the 3 and 4 wire ones are better because they are heated, and will warm up quicker. you can also sit them further away from the engine with no problems, which would be good with the turbo
You can have a look to the web of the "Furious Celica Team" site
