Results 16 to 18 of 18
Thread: 18r-gu noises. Please help.
    Default Re: 18r-gu noises. Please help.
    You can check the right hand side chain guide by removing the front cover on the head and inspecting the guide through there. it sounds like either the guides are worn beyond the limit or the tensioner on the drivers side of the head is out of adjustment.. Just do not over tighten the chain tensioner as it will cause rapid wearing out of the guides. Also any major adjustment of the tensioner will cause the cam timing to be retarded and you may have to reset the cam timing
    Cheers Dave
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Jun 2008
    ca
    Quote Originally Posted by airfireman1
    Cheers Dave
    Cool. Thanks for all the info. I'll be working on it this weekend. How do I know if the guides are bad? And how much tension should be in the chain?
    My friend I think you need to do a search on the forums and see what you can find.
    That or get your hands on a "green book" the 18rg manual.
    Here is a couple of links that might help you with some of your questions.
    http://users.on.net/~csharman/docs/18rgeu.pdf
    http://www.toymods.net/forums/showth...ight=18rg+life
    If you have any specific questions i would be asking them in the 18rg thread.. those guys know everything there is to know.
    Now - RA23-WRX
  1. 18r piston question
    By quikestsilva in forum Tech and Conversions
    Last Post: 20-06-2007, 05:51 PM
  2. 2TG head/ 18R block
    Last Post: 08-06-2007, 01:36 PM
  3. Gearbox noises.. W55
    Last Post: 13-04-2007, 03:20 PM
