Results 1 to 8 of 8
Thread: jza80 master cyl bore dia?
    Penrith BC
    Default jza80 master cyl bore dia?
    as in title... does anyone know the bore dia?
    it is cast onto the thing, but the casting is way underneath and i cant read it. id need a dental mirro to even try and get down there to see... which i will if noone happens to know/find out in an easier fashion...
    ed
    ../delete/ban
    tech moderator
    Jun 2008
    Default Re: jza80 master cyl bore dia?
    It is either 25.4mm or 26.9mm.
    If it is the 16" wheel model then it is definitely 25.4mm.
    Penrith BC
    does the TT version/bigger brakes have a 1 1/16" master? interesting
    ive only got the smaller wheel/brake package (originally) but have upgraded the calipers etc. seems that the dia of the master is currently insufficient.
    was considering boring/resleeving or even going a new master setup altogether, but might sus out the TT master cyl first
    ../delete/ban
    tech moderator
    Jun 2008
    Check out this link.....
    http://mkiv.supras.org.nz/specs.htm
    The brake section is down near the bottom of the page.
    Cheers.
    Jun 2008
    There is more info on JZA80 brakes, gear ratios, diffs etc here:
    http://www.j-garage.com/toyota/supra/a80spec.htm
    Forum Sponsor Backyard Mechanic Soarer21's Avatar
    If I recall correctly the 4 piston version has 1 1/8th master cylinder
    2 piston version has 1 1/16th
    I have a brand new 1 1/16th unit sitting under my desk, ordered accidentally
    I'd rather have a bottle in front of me then a frontal lobotomy
    Penrith BC
    thats different to the above posted data, and i cant find reference to toyota EVER making a 1 1/8" master cyl... biggest is the 1 1/16"
    that said, dont let me talk you out of selling me your 1 1/16" item
    ../delete/ban
    tech moderator
    Hrmm, ok. I think maybe I was misled then on the 4 pot master cylinder dimensions
    I would need to cross check numbers from a 4 pot equipped jza80 chassis code I have with the master to see.
    Not sure you'd like to see the invoice from Toyota for that new master cylinder
    I think it was around $400 but I have it with the cylinder at work where I tossed it in disgust to see it was same as I had already.
    When I put the JZA80 4 piston/2 piston calipers onto my car I found it had a rather long brake pedal travel. Its possible it was pedal ratio that created it though. I havent seen a JZA80 pedal to compare.
    If you desire 1 1/16th master new then Im happy to cut a deal on a cylinder I wont ever be using
  1. Replies: 1
    Last Post: 28-04-2011, 11:45 PM
  2. MR2 Brake master and proportioning upgrade
    By Joshstix in forum Tech and Conversions
    Last Post: 27-02-2008, 02:57 PM
  3. TA22 master cylinder with 1 inch bore?
    Last Post: 19-06-2007, 08:22 AM
  4. Replies: 3
    Last Post: 06-07-2006, 06:11 PM
