Results 1 to 15 of 20
Thread: Narrowest G series live axle available?
    Forum Sponsor Backyard Mechanic Soarer21's Avatar
    Default Narrowest G series live axle available?
    I did a quick looksie but didnt spot anything obvious.
    Does anyone know the width and what vehicle had the narrowest available G series differential assembly?
    I "think" maybe it was a Hiace? Is this right?
    Any idea on actual widths?
    Thanks
    John
    I'd rather have a bottle in front of me then a frontal lobotomy
    Default Re: Narrowest G series live axle available?
    Pretty sure it is RN27 @ 1370mm?
    Kudos to Teh Witzl!
    http://toymods.net/forums/showthread.php?t=941
    Quote Originally Posted by Witzl
    Now, some use[less] info from Teh Witzl!
    # RN2* Hilux = 1370mm width, will measure drum size tonight
    # RN4*/YN4* Hilux = 1410mm width, unsure of drum size (i think 8"?)
    # UZS131 Crown = G series, IRS, G474 code iirc, non-LSD
    # AE71/KE70 = ghey bog warmer, 1410mm width, p00
    # TE72 (aka T18) = T sereies, 3.9:1 ratio, open centre, 1410mm width
    Hiace is definitely wider than Hilux's as I have a Hiace diff and that is why I had to run the big +ve offset wheels to keep them in the guards.
    QUICKEST 1JZ'S IN OZ
    yeah the hiace diffs are up around the 1490 or 1500mm width IIRC.
    RN27 is definitely the narrowest at 1370mm, followed by RN4* series at around 1410mm.
    Ok cool. thanks for that. If my scientific estimates are right it'll be 80mm narrower then what I have to start with
    if you are looking for wider versions.... then the old taragos have wider widths again.
    No thankee Narrow is good. Just like a womans hips...
    The old One Backyard Mechanic
    Weren't the tarago's F series?
    Cheers Craig
    Yeah, I thought a lot of the early Taragos were F series. Better check that to be sure.
    Hiace is something like 1570mm from memory.
    Yep, was running a 1370mm hilux in my sprinter
    Pretty sure that's the narrowest
    I dont suppose anyone has one of these 1370mm jobs lying around gathering spiders?
    i've got a 1410 from a rn46 hilux - 6 stud job. The rn2x is damn hard to get but i'll keep an eye out for ya.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Any idea what a 1400mm G series would be then? As mine from drum to drum was 1400...
    Cheers<
    Jase
    JZA023
    Junior Member Grease Monkey crostek's Avatar
    Quote Originally Posted by Soarer21
    EMP? had one a while ago he may part with it for the right money,
    I am getting one from later model hilux shortened at the moment to fit KE70
    John..... the RN27 axles are not only hard to find, but usually quite expensive to boot (if you find one).
    I've only ever found TWO. One of them, Rod found at picknpayless on a roll-over smashed hilux - the whole axle was shaped like a banana.
    The other, came up for sale on these forums and was sold to me within 15 minutes (followed by around 15 people begging for 2nd dibs) - i eventually sold it on to someone else.
    One thing worth noting about the RN27 housing is that the diff centre carrier is a little smaller than later model G series housings, and wont directly fit a Toyota G series torsen centre. You need to get the pinion gear shortened, the crown wheel spaced, and something special done with the bearings..... IIRC
    There are one or two threads around on this torsen-not-fitting topic.
  1. F series diff question
    By Wedged'86 in forum Tech and Conversions
    Last Post: 16-08-2010, 08:51 PM
  2. F series Live Axle Bearing Cap's order
    By Screamn_Sleeka in forum Tech and Conversions
    Last Post: 21-04-2007, 08:55 PM
  3. F Series Diff - MA61 pinion housing to MX23?
    Last Post: 14-03-2007, 11:54 AM
  4. Live Axle Setups
    By TheStitt in forum Tech and Conversions
    Last Post: 15-12-2005, 08:36 AM
