Results 1 to 6 of 6
Thread: HKS cams for 1jz-gte
    Default HKS cams for 1jz-gte
    Does anyone know the exact details of these cams? 256,264,272.
    [email protected]"
    max lift
    lobe centre
    I am a cam noob but any other details required to make something close would be good.
    Thanks
    Chris
    QUICKEST 1JZ'S IN OZ
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    Default Re: HKS cams for 1jz-gte
    256:
    8.7mm lift
    110deg lobe centre inlet
    115deg lobe cente exh.
    264:
    9.0mm lift
    115deg lobe centre exh.
    272:
    9.3mm lift inlet
    9.0mm life exh.
    I am not a doctor, or a mechanic...
    A.K.A Otomoto
    All new - Fart!
    Quote Originally Posted by Vios-GT_07
    it was 10,000 kms b4 it saw the red-line.. but even then i seldom push it that hard unless i have to prove a point i.e. competition
    thanks mate.
    BTW I do know that 272's for 2jz are
    222* @ .050" in and exh.
    BTW this is what a stock 1jz has
    1JZ Stk Int: 189 @ 050, 303 lift 7.7mm
    1JZ Stk Exh: 194 @ 050, 313 lift 7.9mm
    anyone have an idea what sort of power levels one should start looking at doing cams?
    what sort of gains they give?
    is it worth it with an auto?
    General consensus is that around 280rwkw through an auto and up you would benefit with cams. (although there are exceptions) I have found that on the stock cams power seems to drop off about 6500rpm with a single turbo setup. Mr 1jz has found the same. The cams should help it breath up top and flatten out the powerband.
    As you would expect on a 1jz with such tiny turbos designed to bring it on boost quickly, the cams are suited to this also so top end flow isn’t the priority.
    Also, some people have used 264/264 cams on stock twins setups and has made good improvements so it isn’t only for single turbo people.
    I would only do it if you have an aftermarket ecu though as I remember something about it doing silly things with the cam sensors.
    interesting
  1. Rust on the cams - how to clean/repair?
    By jamin in forum Tech and Conversions
    Last Post: 05-02-2006, 02:49 PM
  2. 3SGTE cams into a 3SGE motor...Pros/Cons?
    By MFN-MAN in forum Tech and Conversions
    Last Post: 01-02-2006, 03:19 PM
  3. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
  4. 2jzgte cams in 1jzgte do they fit without mod
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 12-01-2006, 08:54 AM
