Not quite as easy as wandering in and asking for them off the shelf is it?Originally Posted by EVOSTi
Ok, I understand what you mean however refering to the below picture. Top one is a conventional HKS coilovers from a JZX90 (although its copped overspray in black) and the bottom is an S15 HD coilover.Originally Posted by JustenGT8
The HKS unit is never going to go lower then the spring length will allow based upon the available threads on the sleeve fitted. If the sleeve is fitted with an appropriate length coil spring so its positioned around midway along its length then you can go either direction up or down. With the right installation using a tender spring the primary spring can remain trapped however damper stroke will be compromised. Its still better then a lowered spring though wouldn't you agree?
Optimally a setup using the lower pictured coilover with adjustable stroke that affects neighter spring entrapment nor damper position is the best but even that can be achieved.
I intend to use a coilover similar to the lower one, but seperate spring from body. The problem with mounting the coilover as a whole off the rear of the diff housing is it introduces a twisting to the housing against the trailing arms which isnt really desireable. An extremely short assembly "could" be mounted on top but you'd still need to remove the upper spring mount and bring the whole lot up into the boot to give it sufficient movement.
The best compromise especially for a registered car is to make it adjustable as per the picture, if possible use a tender spring and go from there.
